fmb78
in General Discussion 2 years and 4 months ago
Rear Cornice repair
Hello all, My rear cornice needs to be repaired (or replaced), and I’m in search of any reputable recommendations that any of you may have…
Updated 2 years and 3 months ago
jrs84o
Winter Tree Sap
I cut a couple of 4” diameter, low branches, off of a big old pine tree in my backyard. Everything looked fine until it started…
jrs84o
Winter Tree Sap
annissa12
Cellulose insulation
Has anyone used cellulose batts or sprayed-on loose cellulose insulation? I’m gutting a house that was in rough shape so the walls are all open.…
8
Updated 2 years and 4 months ago
fmb78
Rear Cornice repair
thewinduprobot
Manhattan electrical work question
Any electricians in Manhattan ? Current washer dryer combo is hardwired and a mess. Wire burnt and electrician wants to redo wiring and put in…
trini73diva
Reglazing a tub
Anyone recommend someone for the Brooklyn area to reglaze a tub?
jaay
French drain?
Getting some water in the basement on one side (after those torrential rains last week). We can see the spot we think the waters seeping…
trini73diva
Main sewer line location
I see a large cast iron pipe that goes from the back to front along the wall (about half the length of the house) but…
trini73diva
teresagilhooly
Sidewalk Gate
Dilemma. Have a ground floor apartment. Theres a sidewalk gate to enter onto the property. Need a way to prevent people from entering onto the…
cate
Flat roof replacement
What are people using to add a layer on a flat roof on row houses these days? (Apart from torch down roofs, which are no…
annissa12
Augustiner
Solar net-metering on multifamily rental property
I’ve been wondering about this: If you install a big PV solar panels on a 3 family rental property there is not much to offset…
eg66
in General Discussion 2 years and 6 months ago
Time for a basement waterproofing inquiry!
Has anyone successfully waterproofed a basement and had it hold up to, e.g., today’s flooding? Our new-to-use cellar (approx 40% above grade, last refinished in…
35
solehappy
insurance skyrocketing
welp after doubling in 2023 my insurance through chubb is increasing another 50% for 2024. this is a pretty modest 3 story brick townhome with…
12
teresagilhooly
Sidewalk Gate
louisahml
Roof Inspection Review
Hi all, I wanted to take a moment to thank and give praise to Steve/Home Inspector for his work on a roof inspection. I received…
NewToMarket
Dishwasher Installation
Hi all – We bought a new dishwasher and the seller’s installers said they couldn’t install the dishwasher because the water connections are behind the…
Augustiner
