decoart
in Renovation 2 years and 9 months ago
Mini splits mounted on back of building
I am considering installing mini splits for my 3-family building in brooklyn. Each floor will have it’s own condenser. Can the condenser be installed on…
Updated 2 years and 9 months ago
mzaman718
in General Discussion 2 years and 9 months ago
LPC approval process for windows in NYC
The process for installing landmark windows in New York City (NYC) involves complying with specific regulations and guidelines set forth by the NYC Landmarks Preservation…
ib28
Deck Stair Height Question
I know that backyard decks in NYC are required to have a railing height of at least 42 inches per code. But what about the…
huesos
Attorney Needed for Non-Primary Residence Case
We have a rent-stabilized tenant that owns a home in New Jersey and although she occasionally stays at our apartment, she rents out a room…
heightsgirl
Floor Refinisher
Can anyone recommend a good floor refinisher in addition to the requisite Verrazano’s and Carlos companies?
jayreid1718
Sanitation ticket from previous owner
Hi, I purchased a townhouse last year, and recently the seller notified me of a sanitation ticket that happened when he was the owner. The…
deva
Water Seeping Through Metal Gates on the Ground for Access Into Basement
Anyone has solved this issue? I have metal gates/doors that allow access into the basement from outside. When it rains heavily the water seeps through…
StoopLady
DOB No Penalty Deck Inspection
Has anyone done this? https://portal.311.nyc.gov/article/?kanumber=KA-01909 I kind of don’t get it. Do they just issue you violations? Or do they actually produce useful information?
xrmohyfsuivckb
Gorgeous Exterior Brownstone Doors
Original Brownstone Doors with iron grill work. Great condition. Measurements: brick to brick 60 casing to casing 59 height of door 87 Already removed from…
williamsonchristine64
Lawyer insights needed new building next door
Hi everyone, A developer will soon be purchasing the empty lot next to our 3 family brick building on a residential block in Brooklyn (where…
kachuri999
ISO installer for ceiling fans
Can anyone recommend someone to install a few ceiling fans? The person I used to use moved out of the city.
markwalker
Question about Lighting
Good afternoon, we are now planning our light fixtures and I have some questions. The robots on most websites where you buy these things do…
20
Guest User | 0 secs ago
Storm drain in backyard question
I’ve got a very tiny backyard (roughly 18′ by 17′) that was previously covered with large flagstones and cement… and which would flood almost uncontrollably…
lkrshacmzcy
One Man HVAC Shop
Who has a solid Go-To HVAC contractor they work with; one that isn’t a part of a large company. I know they are probably swamped,…
deva
Need Expert in Split System AC
Dear Community, Need your help. Installed a split AC system in my upstairs unit. Never used it since we installed it two years ago and…
markwalker
Question about Kitchen Faucets
Do you know how to figure out the correct “reach” of a kitchen faucet? This is for a undermount sink. We would want the water…
housepoor
in Heating and Cooling 2 years and 9 months ago
Does a furnace have to be registered or inspected?
I have a hot air furnace in a 10 unit building. The former owner insisted that the furnace does not have to be registered with…
alexisf
Architect advice on egress door - NYC
Hi, would any registered architect or building inspector be willing to look at a schematic and tell me whether or not a proposed new door…
alexisf
in Dept. of Buildings (DOB) 2 years and 9 months ago
Compliant Egress Door Question for RA
jrs84o
CofO or No CofO-- Whats More "Valuable"
So, just as a thought experiment, lets say someone was thinking about selling a three story Brooklyn Limestone after many years of use. Along the…
8
