Recommended Split System for Heat
We are doing a very close to gut reno in Crown Heights. 3 levels in a 19×37 townhouse with the bottom floor to be a rental. It’s been recommended by 2 hvac guys that we install a mini split system to use for both cooling and heat, to avoid having to fully install hot water radiator system as well (would have to get a new boiler). Reading through the site I can see that people don’t recommend relying just on a mini split for heat…. my question is why would the hvac guy and our contractor be recommended it??? It sounds like it should just be a back up option for heat. Did anyone have a split system and use it for heat this winter and survive? Should I be pushing for the hot water radiator system? Any opinions would be greatly appreciated! Thanks!
janaeliuk
in Heating and Cooling 11 years ago
21
bliz | 11 years ago
object(WP_User)#5114 (8) {
  object(stdClass)#5102 (12) {
    string(6) "180531"
    string(4) "bliz"
    string(63) "$wp$2y$10$hz6XFCqGeojEANUqamluJu0ZJ6oRrHz9i.BFr1E6AwLcehFsputgS"
    string(4) "bliz"
    string(23) "petereide@earthlink.net"
    string(19) "2017-08-10 14:09:43"
    string(4) "bliz"
  int(180531)
Get the hot water radiant installed.
