Boiler seems empty, not sure why?
So I usually flush the rusty water out of the gas boiler once a month or so, just run it until it’s clear. I went to do that today and nothing came out and the water fill glass was empty. Boiler has an automatic refill which had both a green and red light lit up and it didn’t kick on to refill.
Obviously the boiler isn’t being used now but any ideas what the issue could be?
And can I leave it as it until our pre-heating season servicing or could it cause issues by leaving it completely empty for next few months?
If helpful, it’s a gas boiler for a 1-pipe steam radiator system. Thank you all for any advice!
stickerhappy
in Heating and Cooling 4 years and 9 months ago
45
The black box with the lights on it has a reset button. That said your boiler should not be empty. Sounds like a serious leak
stickerhappy | 4 years and 9 months ago
object(WP_User)#5340 (8) {
object(stdClass)#5344 (12) {
string(6) "100776"
string(12) "stickerhappy"
int(100776)
Eman……?
object(WP_User)#5345 (8) {
object(stdClass)#5346 (12) {
string(6) "100776"
int(100776)
Which part is the low water cutoff?
push the reset button on the low water cutoff
object(WP_User)#5162 (8) {
object(stdClass)#5160 (12) {
string(6) "100776"
int(100776)
Here’s a photo….
[DCA1A1A3-9096-4096-B0AC-0777C075432F](//muut.com/u/brownstoner/s3/:brownstoner:3bh7:dca1a1a390964096b0ac0777c075432f.jpeg.jpg)
