Boiler seems empty, not sure why?
One day when in person meetings are practical….
cate
in Heating and Cooling 4 years and 9 months ago
45
stickerhappy | 4 years and 9 months ago
object(WP_User)#5358 (8) {
object(stdClass)#5345 (12) {
string(6) "100776"
string(12) "stickerhappy"
int(100776)
So I usually flush the rusty water out of the gas boiler once a month or so, just run it until it’s clear. I went to do that today and nothing came out and the water fill glass was empty. Boiler has an automatic refill which had both a green and red light lit up and it didn’t kick on to refill.
Obviously the boiler isn’t being used now but any ideas what the issue could be?
And can I leave it as it until our pre-heating season servicing or could it cause issues by leaving it completely empty for next few months?
If helpful, it’s a gas boiler for a 1-pipe steam radiator system. Thank you all for any advice!
object(WP_User)#5357 (8) {
object(stdClass)#5356 (12) {
string(6) "100776"
int(100776)
Here’s a photo….
[DCA1A1A3-9096-4096-B0AC-0777C075432F](//muut.com/u/brownstoner/s3/:brownstoner:3bh7:dca1a1a390964096b0ac0777c075432f.jpeg.jpg)
push the reset button on the low water cutoff
object(WP_User)#5360 (8) {
object(stdClass)#5361 (12) {
string(6) "100776"
int(100776)
Which part is the low water cutoff?
object(WP_User)#5362 (8) {
object(stdClass)#5363 (12) {
string(6) "100776"
int(100776)
Eman……?
The black box with the lights on it has a reset button. That said your boiler should not be empty. Sounds like a serious leak
You would be way wiser to tae care of this now rather than during heating season when everyone is booked up….drop me a line at errol832000@hotmail.com if you want me to take a look
ellenlourie | 4 years and 9 months ago
object(WP_User)#5157 (8) {
Boiler is empty for a reason. Resetting manual reset low water cut off will not address the issue. Where did the water go? Ask this question.
lkrshacmzcy | 4 years and 9 months ago
object(stdClass)#5158 (12) {
string(6) "209518"
string(11) "lkrshacmzcy"
int(209518)
Heating Systems, for the most part, are closed loop systems.
I know what Eman means but Gennady is right. If the water has gone that low, there is a reason.
Also do not assume because you do not see a leak there isn’t one….
object(WP_User)#5365 (8) {
object(stdClass)#5358 (12) {
string(6) "209518"
int(209518)
object(stdClass)#5160 (12) {
string(6) "100776"
int(100776)
Thanks guys- I don’t see any obvious leak location. Never saw water on boiler room floor, no leaky risers or mains in basement. It’s not a big building so seems like there are only so many spots it could leak, right?
object(stdClass)#5357 (12) {
string(6) "209518"
int(209518)
I think this is what we are trying to say: you may not see the leak but likely there is one if the water is dropping that low.
There are a lot of places it can leak without you seeing…
object(WP_User)#5160 (8) {
object(stdClass)#5365 (12) {
string(6) "209518"
int(209518)
object(stdClass)#5157 (12) {
string(6) "100776"
int(100776)
I see, but in your experience when you don’t see the leak, what are those hidden leaky spots usually— someplace on or around the boiler itself or the risers or what?
andriywww1990 | 4 years and 9 months ago
in my house they do not seem to leak by the boiler and that may be because the boiler has been changed twice and the pipes around it maybe much newer. the problems in my house are on the older pipes, a little further from the boiler.
Why has nobody suggested pulling and cleaning the probe? That should be the first step if the fill valve(ie low water cutoff) ain’t woikin(that’s my plumber voice). Well after reseting or power cycling it anyway.
Master Plvmber | 4 years and 9 months ago
object(stdClass)#5369 (12) {
Please post a couple more wide pictures around the boiler with more light. I don’t think that’s a reset button on that low water cutoff (LWCO). I think it’s a test button. This could be a long conversation about LWCOs and the need for the type of unit that has both a test button *and a reset button, but I’ll spare you. For now, your water went somewhere, losing it didn’t trigger your feeder, and you’re missing a manual reset LWCO. You’ve got some stuff to work out.
object(stdClass)#5370 (12) {
string(6) "100776"
int(100776)
Photos… [1287052F-9AD4-4004-A77E-E2586787D6E7](//muut.com/u/brownstoner/s3/:brownstoner:CDXo:1287052f9ad44004a77ee2586787d6e7.jpeg.jpg) [59C01FD8-2CDD-44D6-96E5-4A0837AA429D](//muut.com/u/brownstoner/s3/:brownstoner:msRi:59c01fd82cdd44d696e54a0837aa429d.jpeg.jpg) [ADD13EF3-951B-4FD4-A8E1-DDC81BFE9103](//muut.com/u/brownstoner/s3/:brownstoner:hMiG:add13ef3951b4fd4a8e1ddc81bfe9103.jpeg.jpg) [F6D6B145-1622-4F51-BB3D-0BC295471B17](//muut.com/u/brownstoner/s3/:brownstoner:Ipja:f6d6b14516224f51bb3d0bc295471b17.jpeg.jpg) [95D2B630-FB16-4B3C-8FB3-5FB589C06798](//muut.com/u/brownstoner/s3/:brownstoner:frA3:95d2b630fb164b3c8fb35fb589c06798.jpeg.jpg) [47043868-A8C9-4DAB-98F6-CB2912E6BFCB](//muut.com/u/brownstoner/s3/:brownstoner:WAus:47043868a8c94dab98f6cb2912e6bfcb.jpeg.jpg) [1F05A476-DE19-44D6-A328-61FA9D9A6800](//muut.com/u/brownstoner/s3/:brownstoner:sOYH:1f05a476de1944d6a32861fa9d9a6800.jpeg.jpg)
object(stdClass)#5371 (12) {
string(6) "100776"
int(100776)
More…. [8D6076BF-D69C-48B8-A649-2553E10B4860](//muut.com/u/brownstoner/s3/:brownstoner:1smG:8d6076bfd69c48b8a6492553e10b4860.jpeg.jpg) [2589B5A7-4852-4971-8E82-BAC7899C38F9](//muut.com/u/brownstoner/s3/:brownstoner:DTlq:2589b5a7485249718e82bac7899c38f9.jpeg.jpg) [C21B7BF8-8881-41AF-8B1B-7F734346B606](//muut.com/u/brownstoner/s3/:brownstoner:J8Wy:c21b7bf8888141af8b1b7f734346b606.jpeg.jpg)
