Risks vs. Rewards of Switching to Radiant Floor Heat in Bathrooms
Great! Thank you janedrew
cate
in General Discussion 6 years and 2 months ago
33
cate | 6 years and 2 months ago
object(WP_User)#5261 (8) {
  object(stdClass)#5088 (12) {
We are considering replacing our existing sheet vinyl and wood subfloors in our bathrooms with ceramic tile, which raises the question of whether we should replace the existing hot water heat pipes with radiant floor heat at the same time. The existing heat is working beautifully. The advantage would be to open up space for storage or seating in a garden level hallway by eliminating two awkwardly positioned heat risers there. I am wondering: (1) How long do the radiant systems last and how reliable are they — will we will be tearing up the tile in 10 years when a circuit fails? (2) Will removing the two heat risers affect our existing hot water radiator system? They are a branch line and lead only to those two bathrooms. (3) Anything else I should know about the pros, cons, costs, installation? Thank you!
lkrshacmzcy | 6 years and 2 months ago
object(WP_User)#5260 (8) {
  object(stdClass)#5259 (12) {
    string(6) "209518"
    string(11) "lkrshacmzcy"
  int(209518)
Radiant Heat is my personal preference for any type of heat; even as a company that focuses on Steam Heat. It is tough to push to others though because it is so invasive; seems like a good chance for you through.
Consult with a professional if you are not one. Hydronic Heat is not like Steam Heat that is based upon radiator calculation but removing and adding lines can throw off the Heat Loss or Circulation Threshold for your system.
object(WP_User)#5088 (8) {
  object(stdClass)#5256 (12) {
    string(6) "209518"
  int(209518)
Master Plvmber | 6 years and 2 months ago
  object(stdClass)#5262 (12) {
My opinion is that if you’re going to do one bathroom with radiant floor heating, you might as well go with underfloor electric mats. I know that’s sacrilege to many in the heating industry but sometimes it just makes most economic sense.
eman134 | 6 years and 2 months ago
object(WP_User)#5256 (8) {
  object(stdClass)#5260 (12) {
with a bathroom midship in a brownstone, radiant floor heat can be an awkward fit, as evinced by the OP’s comment re the risers…..As MP said , electric floor matsvcan be the way to go…Schulter is testate of the art system
https://www.schluter.com/schluter-us/en_US/Floor-Warming/c/FW
hkapstein | 6 years and 2 months ago
  object(stdClass)#5263 (12) {
Where is the bathroom, does it actually need a heat source? It sounds like the plan is electric if the goal is to eliminate the risers. Could you route the risers through the wall? It might be possible to fish up an insulated pex run.
slopefarm | 6 years and 2 months ago
  object(stdClass)#5264 (12) {
    string(3) "655"
    string(9) "slopefarm"
  int(655)
We did what MP suggests in 2 bathrooms and we are very happy with it. 13 years and counting. The bathrooms get a lot of ambient heat from the house, so a gentle lift and slightly warm floor in the winter from electric radiant heat is really all you need.
  object(stdClass)#5265 (12) {
We were thinking an electric mat, yes. (No wall space to bury risers.) Glad to know they’ve been performing well for Slopefarm. Anyone know how long these systems can be expected to last? Seems like a potential heap of trouble down the road.
  object(stdClass)#5266 (12) {
Well it shouldn’t cost much to put it in, and if it goes out in a few years, you can put an electric towel warmer on the circuit. I’d try to put it on some kind of timer or motion sensor switch so you don’t waste a ton of electricity.
object(WP_User)#5265 (8) {
  object(stdClass)#5261 (12) {
    string(6) "209518"
  int(209518)
Love the Towel Warmers!
object(WP_User)#5266 (8) {
    string(6) "209518"
  int(209518)
dougb | 6 years and 2 months ago
    string(6) "180076"
    string(5) "dougb"
    string(34) "$P$Br2q0HTR5CEFuU7yVEGeR5P/eS8PuK."
    string(5) "dougb"
    string(16) "dbruha@gmail.com"
    string(5) "dougb"
  int(180076)
One tip I’ve seen is to be sure to install a backup temp sensor in the floor of electric mat systems. Sounds like that is more likely to fail than the mat itself, and by having wires for a second sensor available if the first sensor fails at any time, you can just switch over without needing to figure out another way to mount a replacement sensor under your tiled floor.
warmsmeallup | 6 years and 2 months ago
    string(5) "16829"
    string(12) "warmsmeallup"
    string(34) "$P$BkJLL.FDWWkU/x5/l4te96Qo5/Nr.u0"
    string(26) "russell@comfortradiant.net"
    string(29) "http://www.comfortradiant.net"
    string(19) "2008-09-11 14:19:05"
  int(16829)
Installing radiant floor heat in a bathroom can be viewed 3 ways:
It’s needed to support a primary, insufficient source.
It’s needed as a primary source for heat (requiring a heat load calculation) or,
Strictly from a comfort standpoint.
The first two speak for themselves. If it’s from a comfort point, there’s nothing like stepping out of the shower on to a warm floor or, walking in to the bathroom in the middle of the night to a warm floor. Until you’ve experienced it, it can’t effectively be described. As far as to which system to use, depending on the actual coverage, bathrooms are usually too small to install a boiler/instant-on water source over just using an electric system with a thermostat and in-floor sensor.
Then it’s a question of whether you also want to heat the shower floor/seat as well. When heating in the shower or the shower seat, we only recommend a low voltage system. Otherwise, the standard roll out 120 or 240v mat or spooled cable will work fine, depending on the design and layout.
Someone in this thread spoke to what you can do wit h the circuit if it fails. If you buy a reputable product with a solid warranty, the system will only fail if someone’s not careful during installation of the system or the tile over the top. The systems we supply and /or install come with minimally a 20-year, non-prorated warranty.
www.comfortradiant.com
  object(stdClass)#5267 (12) {
Does your warranty include labor and the cost of the new tile for 20 years?
  object(stdClass)#5268 (12) {
    string(5) "16829"
  int(16829)
We carry two lines of electric radiant heating. No manufacturer will cover the cost of the tile but since the damage can be traced and repaired, the Danfoss warranty does cover up to 5x the cost of the heating element itself in the form of a check paid to the client if it is found to be a factory defect. No other company in the U.S. will do that.
I’ve been installing electric radiant for 15 years and I’ve never seen a CORRECTLY INSTALLED electric radiant system fail. I have seen many damaged but once traced, you can see what caused it to fail.
object(WP_User)#5267 (8) {
So like 1000 dollars to redo the floor?
hancockone | 6 years and 2 months ago
object(WP_User)#5268 (8) {
    string(5) "27887"
    string(10) "hancockone"
  int(27887)
I did the bathroom Reno 12years ago. I recessed the radiator into the wall To free up floor space and installed electric radiant mat under ceramic tile. I installed a backup sensor at the time in case the first one fails. It is for comfort not primary heating. Just love it and so do my cats. Also installed an electric towel warmer which is a nice little luxury.
A motion sensor wouldn’t be helpful in a slow reacting system like radiant floor heating.
  object(stdClass)#5269 (12) {
Yes, it can turn it off when no one is there.
