Cold radiator
Thanks eman, we have a bunch of stuff for you, none of which are all that urgent so we were going to wait till summer. Talk then!
greenworks
31
object(WP_User)#5035 (8) {
  object(stdClass)#5023 (12) {
Cate. Check the temperature of the top of that one against the temps of the tops of the others. I f this were my house i would shoot and infrared thermometer at them. It sounds like it still might have some air in it and some other factor in the system has it getting warmer today. Perhaps the system is cycling more and heating it albeit slowly. From what you said the other day, my money says this radiator is not going to get as hot as the others.
I worked in two buildings with hot watet heat. One radiator at the top of a five story staircase was barely warm. I have no idea when the last time anyone had bled anything on that loop was. I bled all of the air out and it got hotter. I might have gone through and bled some other radiators but after a few days, i bled the one at the top of the stairs again and got more air out and it finally worked.
In another building i had a hot water loop and there was no uniformity between any radiators. I think i went around and bled all of them for the sake of it. Even those working well had some air in them.
For conversation sake. I am going to ask my mother if she had a reason for bleeding the radiators in the house i grew up in and if she did just one radiator or all of them. You get a different, not always correct, perspective on this stuff from untrained lay people who really do not know what is going on in the system. The plumbers, they know.
cate | 3 years and 3 months ago
object(WP_User)#5034 (8) {
  object(stdClass)#5033 (12) {
Thank you, Steve!
greenworks | 3 years and 3 months ago
object(WP_User)#5238 (8) {
  object(stdClass)#5239 (12) {
    string(6) "193898"
    string(10) "greenworks"
  int(193898)
Great to hear cate!
Follow up question – didn’t want to post until cate got an answer – we have a single small hot water radiator farthest from boiler that isn’t getting hot at all. I’ve bled it and plain water comes out, no air. Valve is open. Even though farthest from boiler, the primary bedroom radiator just on other side of wall works great.
What next to troubleshoot?
object(WP_User)#5030 (8) {
  object(stdClass)#5241 (12) {
sorry boo. any time i bled a radiator it came back to life. i do not know enough about these systems to guess. i will ask, does this have any sort of a second valve on the outlet side?
object(WP_User)#5239 (8) {
  object(stdClass)#5034 (12) {
boo, i cannot help there. any time i bled a radiator it ended up working. i wonder if a section of pipe can be isolated from the radiator or have a high spot in it and have an air lock. i do not know how to void that. on my own house, if i had hot water heat, i would mess around with it until i got it but i can’t suggest that here. i won’t even read about it and suggest as someone can get hurt. Plumber’s job.
object(WP_User)#5241 (8) {
  object(stdClass)#5238 (12) {
Boo, i read about the hot water systems last night. There is a valve on the outlet (in the same way that two pipe steam has a trap on the outlet) that is adjusted by a “plumber” when they install the radiator. Obviously when they say “plumber” they don’t think homeowners should mess with it. also, for those of us not trained in these things, once we begin tampering with one thing, we can mess something else up on a system.
They also talk about them being “bound” with air which makes me think of a vapor lock or air lock in the fuel line of my old diesel truck (you clear them by opening a connection) but i have no idea what a plumber would do here.
For anyone reading this: the licensing boards for home inspectors (probably at the behest of the real estate industry) do NOT want home inspectors guessing at what is wrong with a house beyond what they see (“the radiator in the master bedroom is not getting warm”). This is because along with not really knowing because we are not (take your pick: plumbers, electricians, engineers) if we start diagnosing and incor rectly specifying what has to be done to correct something (and the cost of such), it can unfairly influence the sale of a home. Contractors face this all the time anyway because “somebody told somebody something” and they had no idea what they were talking about and then in addition to having to justify the job they have to explain why what someone said is wrong.
  object(stdClass)#5030 (12) {
    string(6) "193898"
  int(193898)
Thanks Steve! Will do deep dive into your responses!
string(6) "201692"
i have yet to see a hot water system with a flow setting valve that steve suggests exists on your system …hire a competent heating professional to figure out what is wrong…Petri, Gateway, etc
object(WP_User)#5240 (8) {
  object(stdClass)#5242 (12) {
Eman, i don’t recall these valves being on any of the hot water systems in buildings i worked in either and am not sure if this is something newer to the market (its been decades for me). The valve i am referring to is a “lockshield” and according to what i just read it is used to restrict the flow of water through the radiator so radiators down stream get enough heated water. It is used to “balance” the system (their terminology). It looks like danfoss makes some of these which has me thinking this is some recent idea from across the pond.
object(WP_User)#5243 (8) {
  object(stdClass)#5244 (12) {
    string(6) "193898"
  int(193898)
Eman, you were the one I was hoping would respond! Not throwing your own hat in to the ring or too modest to do so?
We were going to reach out to you in summer bc we have a to do list for you before we start another project and this issue was on the list-was hoping there might be something we could do in interim but thankfully the room in question isn’t used very often
string(6) "201692"
i didn’t want to recommend myself because i am currently swamped with work…if you can wait two weeks or so my schedule should open up….errol832000@hotmail.com
