Cold radiator
One of our radiators is not getting hot. I suspect it’s because the end closest to the hot water pipe is tilted down and the end farthest from the hot water pipe is tilted up, so probably the radiator is not filling with hot water. (The fin closest to the hot water pipe is warm.) It’s a hot water system. The radiator is on a floor that has settled about three inches, at least, and is slanting. Can we shim the radiator — without cracking any pipes? Or should we shim the floor? Thank you and Happy Thanksgiving!
cate
31
cate | 3 years and 3 months ago
object(WP_User)#5238 (8) {
  object(stdClass)#5023 (12) {
Thank you, Eman. Are there other things we should be looking at or discussing with our licensed heating plumber?
object(WP_User)#5035 (8) {
  object(stdClass)#5034 (12) {
And cate, it does not matter if it is the first or last radiator. If air gets into the radiator, it will rise and sit there until it is bled off. Some of the newer systems have an automatic valve that voids the air at the end of the run near the boiler and maybe along the run but the house i grew up in and any buildings i have worked in with hot water heat never had that device. Manual bleeding.
string(6) "201692"
slope has zero effect on a hot water radiator
object(WP_User)#5239 (8) {
  object(stdClass)#5241 (12) {
Colonial: hot water heat systems are two pipe at the radiator – an inlet and outlet – and they do not have a vent. They have a bleeder valve which is open to bleed air out of the system.
Steam systems have vents.
Op says this is a hot water system.
colonialrevival | 3 years and 3 months ago
object(WP_User)#5240 (8) {
  object(stdClass)#5242 (12) {
    string(6) "195334"
    string(15) "colonialrevival"
  int(195334)
I’m not terribly familiar with two pipe systems, but if this were happening in a one pipe system I’d double-check the vent for a blockage.
object(WP_User)#5241 (8) {
  object(stdClass)#5238 (12) {
Did you bleed the radiator? Just because water passes through it to go someplace else does not mean air is not inside it. The air could be sitting up high.
cate | 3 years and 4 months ago
  object(stdClass)#5248 (12) {
It’s a hot water system. It’s not the first or the last radiator in the system, it’s on the garden floor, and the two radiators above it get really hot. I don’t think we had this problem in prior years. Earlier this year we put in a beam under the floor where one was missing, although we didn’t jack up the floor or change anything enough to crack anything. But it’s possible that independent of that the floor is sagging even more than before and causing a more pronounced slant. I’m not sure.
  object(stdClass)#5240 (12) {
So, is this a hot water system or a steam system? I read “hot water pipe” and assumed it was hot water. But it is one pipe? Steam? If it is not pitched correctly, water will not drain and it will bang. Is the vent working? It it the furthest radiator from the boiler? And maybe the vent is small and the system cycles off before it gets hot?
lkrshacmzcy | 3 years and 4 months ago
object(WP_User)#5248 (8) {
    string(6) "209518"
    string(11) "lkrshacmzcy"
  int(209518)
Loaded question but pitch is a good place to start
  object(stdClass)#5239 (12) {
    string(6) "209518"
  int(209518)
  object(stdClass)#5243 (12) {
Bleed it. The screw on top of it.
Brownstonehomeinspection.com
