Office cleaning companies
http://cdn.brownstoner.com/4ecb79596bdf8-.jpg
Dry Cleaning Method Vs Steam Method
There are certain dry methods available for office carpet cleaning. The dry cleaning method uses absorbents that absorbs all the dirt and stains from the carpet and all you need to do after the process is complete is to vacuum out the dry cleaning agent from the carpet along with the dirt. The dry method is highly effective in situations where you have very less time and you need to clean your carpet of the dirt and grime that has accumulated
Some like cleaning office carpets with the steam method. Although this method is highly effective in getting the stains and dirt out of the carpet, this method can also damage the carpet as well. Moreover, this method is also not efficient is taking out any stain that might have altered the color of your carpet. For example, wine stains are difficult to remove from plain clothes and when spilled on a carpet they might alter some base color of the carpet itself. The steam method is inefficient in getting rid of such stains Source@ http://nationalcleaningassociation.com/
davidhart
in Carpet and Upholstery 14 years and 5 months ago
derval | 10 years and 11 months ago
object(WP_User)#5066 (8) {
object(stdClass)#5087 (12) {
string(6) "193561"
string(6) "derval"
string(34) "$P$BPtHXN.7cCOXcN.a7ApfIZHi5JJwn7."
string(6) "derval"
string(21) "derval.whelan@fox.com"
string(19) "2024-02-23 11:07:44"
string(27) "DERVAL WHELAN DERVAL WHELAN"
int(193561)
Thank you for sharing with us…..!!!
greenaircleaning | 11 years and 5 months ago
object(WP_User)#5067 (8) {
object(stdClass)#5068 (12) {
string(6) "183511"
string(16) "greenaircleaning"
string(34) "$P$Bn4urKTbrXsLdWmYoIBazymqGu3.pD1"
string(24) "web@greenaircleaning.com"
string(39) "http://www.progreencleaningservices.com"
string(19) "2017-08-10 13:55:18"
int(183511)
David, there are many differences in cost, effectiveness and equipment when it comes to office carpet cleaning. Keep in mind that with dry carpet cleaning, you can simply purchase a carpet cleaning solvent powder as the only additional piece of equipment or supplies you need. You can then use whatever vacuum cleaner you currently use for daily vacuuming and remove the solvent powder with the dirt in it. Steam carpet cleaning is obviously going to utilize a carpet extractor and therefore requires another piece of equipment and is more costly, but is more effective. There are many self-contained units that can apply the carpet solution and rinse the carpets with one single pass-through of the machine, and therefore those are the machines to target. You can rent a carpet extractor machine from these Rug Doctor locations: http://www.rentrugdoctor.com/ny/brooklyn.html Another option is to use a commercial cleaning service company like the following: http://www.progreencleaningservices.com/ Finally you can rent a carpet cleaner from your local Home Depot at the following: http://www.homedepot.com/c/tool_truck_rental_floorcare_rental_equipment The best carpet cleaning program is to use the dry cleaning method on a regular basis, say once per month, and to use the wet cleaning method on a more frequent basis, such as once per quarter or semi-annually.
