Blocked off roof access hatch
> @namahs
> it sounds like your home inspector/engineer did not do a great job
he did a terrible job, but short of tearing down walls there was no way to know.
randolph
in Roofing 7 years and 8 months ago
34
Guest User | 7 years and 8 months ago
string(6) "199269"
I’m looking at a townhouse that has recently been remodeled. When doing my walk through, I could not find a roof access hatch on the 2nd floor. Apparently, the contractor sheetrocked over it. Seller doesn’t seem inclined to have a contractor go on the roof reopen the roof access hatch. In NYC, is it required that townhouses have a roof access hatch? How can home inspector adequately asses the crawl space and insulation? If there is a future roof leak, does having a roof access hatch serve a purpose other than getting onto the roof more easily? How can I kindly request that the Seller reopen the hatch if you think it is a necessity? Thanks!
slopefarm | 7 years and 8 months ago
object(WP_User)#5425 (8) {
  object(stdClass)#5428 (12) {
    string(3) "655"
    string(9) "slopefarm"
  int(655)
That would trouble me. Were you able to get up onto the roof as part of the inspection? Do you have any roof access at all? If not, that simply isn’t acceptable in my view. I imagine there are code issues here, including fire. But I would also wonder why the seller covered it up, what’s being hidden, etc.
SoSlope | 7 years and 8 months ago
object(WP_User)#5429 (8) {
  object(stdClass)#5430 (12) {
    string(5) "16781"
    string(7) "SoSlope"
    string(7) "SoSlope"
    string(7) "SoSlope"
  int(16781)
There are many reasons to want to be able to access the roof relatively easily (i.e., more easily than setting up a ladder from ground level). I am up there at least a couple of times a year just to check the roof and to make sure that there are no leaves in the gutter. Not having any roof access would be a major issue.
Perhaps more importantly, what contractor would not know this? If he was willing to cut this corner, what other corners did he cut?
string(6) "199269"
Can get onto roof with an x-long ladder. Was told that the roof was recently patched with a liquid membrane in certain parts applied
daveinbedstuy | 7 years and 8 months ago
object(WP_User)#5231 (8) {
  object(stdClass)#5229 (12) {
A roof access hatch won’t allow access to any insulated “cockloft” or “crawlspace” area. Just the roof. Your inspector needs to bring a ladder to inspect the roof.
Arkady | 7 years and 8 months ago
object(WP_User)#5251 (8) {
  object(stdClass)#5427 (12) {
Dibs – My hatch access allows me to get into the cockloft & several of my neighbors have the same. There’s an open stretch between the ceiling of the room below & the actual hatch to the roof. Mine’s about 3 feet at that point. Lets me clean the lay light over the stairwell among other things.
object(WP_User)#5228 (8) {
  object(stdClass)#5438 (12) {
Hmmm, OK. Mine never did nor did any hatch of other houses I looked at. And I had a lay light over the stairwell as well.
string(6) "199269"
Does anyone know if roof hatch is required to have to be up to code? If not, it sounds like i take it at my own risk (risk being that the sheetrock is covering up an uninsulated / damaged roof) assuming Seller doesn’t feel obligated to reopen the hatch.
object(WP_User)#5432 (8) {
  object(stdClass)#5226 (12) {
    string(3) "655"
  int(655)
Well, anyone can get onto a roof from the exterior with an extra long ladder. But that’s a bit impractical as your only route up. As a homeowner, I would not settle for that except in a one or very low two story. I go up on my roof from time to time to check on condition, chat with chimney inspectors, deal with gutters, etc. I also don’t like the idea that this was sheetrocked over. It is an opening in the exterior — more opportunities for water and other problems. I’d want to see the hatch and surrounding area before I bought for signs of leaks, other damage.
How recent is the sheetrocking?
string(6) "199269"
Sheetrocking was done 4 months ago
object(WP_User)#5426 (8) {
  object(stdClass)#5434 (12) {
    string(3) "655"
  int(655)
That’s suspicious.
string(6) "198362"
It is necessary. The basement and roof say a lot about a house and its condition.
randolph | 7 years and 8 months ago
object(WP_User)#5431 (8) {
    string(5) "26171"
    string(8) "randolph"
  int(26171)
> @slopefarm
what do you chat about?
  object(stdClass)#5437 (12) {
    string(3) "655"
  int(655)
I meant chimney cleaners. When someone is working on the house, I like to keep a bit of an eye on them, engage in conversation, get a good sense of them. I learn things about whether I want to use the same things again, as well as about the house.
resident2 | 7 years and 8 months ago
object(WP_User)#5438 (8) {
  object(stdClass)#5231 (12) {
You say the building has “recently been remodeled” was it filed? Are there permits out on the work?
In order to close of a means egress; IE: the roof hatch, it needs to be approved by the DOB.
I doute very seriously that the DOB would approve taking out an existing roof hatch.
string(6) "199269"
How do i find out if permits went out on the work? The DOB website shows 2 that were issued: ALTERATION TYPE 2 – GEN. CONSTR.
FILING APPLICATION FOR INTERIOR RENOVATION AND TO REMOVE VIOLATION NUMBERS… and PLUMBING – ALTERATION TYPE 2
FILING APPLICATION FOR INTERIOR RENOVATION AND TO REMOVE VIOLATION NUMBERS:… In addition, the seller could just say that the existing roof hatch was closed off years prior to re-model construction work.
    string(3) "655"
  int(655)
Since you are on BIS, just click on the links for the various jobs and you should be taken to pages that list permits, if any, plans, violations, etc. Play around with the BIS page for the property and follow the links and see what you learn.
But you may be overthinking this. From what you’ve already posted, I do not trust this situation. Would you be buying this house on the basis that it is recently renovated? You’d be paying a premium for a pig in a poke. My gut tells me they are hiding something.
If you are still interested in going to contract on this, I would be direct. Have your lawyer tell seller’s lawyer something like “my client thinks your client is hiding something and doesn’t have a good feeling about this. He needs to see the roof hatch and the area around it and does not understand why it was covered over.” If the response is no, that tells you all you need to know.
string(6) "199269"
Thanks for all the helpful comments, SF. The agent for the Seller, who has been representing several new townhouse renovation jobs, said that all of these ‘new townhouses’ cover up the cockloft space. Contractors generally raise the top floor ceiling height to the rafters, and put in new insulation. Most will leave the roof hatch available to access with a ladder, but they all sheetrock around it so you can’t look through the cockloft space. Does this sound right to you? I thought the space between the roof and the 2nd floor ceiling needs some airflow, unless brick homes and brownstones have something already built in.
object(WP_User)#5433 (8) {
Sounds like agent for the Seller speak.
