Mini split freon leak
Hi all, we have a leak in the freon line of our mini split. Can anyone recommend someone to check and fix the leak? I’m pretty sure it’s at the coupling. Thanks!
bliz
in Heating and Cooling 21 hrs ago
chrispetriplumbing | 1hr ago
object(WP_User)#5009 (8) {
  object(stdClass)#5026 (12) {
    string(6) "203345"
    string(18) "chrispetriplumbing"
    string(63) "$wp$2y$10$X1sdJ4dl4OXVSPGyLSQqNeNPbT.AVNjJ/bBb6ywBNstdwjMtLd5iK"
    string(22) "chrispetriplumbing-com"
    string(23) "chris@petriplumbing.com"
    string(19) "2018-10-27 00:13:52"
  int(203345)
Make sure whoever you do use walks you through what and how they are going to test and also gives you a few different options on this.
A leak in a system is a really tough one for a homeowner because it can be something as small as a bad flare to a leak on a coil!
CP
