Leaking steam riser pipes
Water leaks from the top of our steam riser pipes when they’re on. It’s causing the plaster on the ceiling around the top of the pipes to rot. Anyone have recommendations for flanges and/or foam insulation that we can use to prevent further leakage?
encarnacionroger
in Heating and Cooling 6 years and 6 months ago
Master Plvmber | 6 years and 6 months ago
object(WP_User)#5170 (8) {
object(stdClass)#5198 (12) {
www.72Fmechanical.com is me.
encarnacionroger | 6 years and 6 months ago
object(WP_User)#5171 (8) {
object(stdClass)#5172 (12) {
string(6) "200251"
string(16) "encarnacionroger"
string(34) "$P$BU50UOjV5UNx/SQxdDY2qJn0jkNSoa/"
string(25) "encarnacionrogergmail-com"
string(26) "encarnacionroger@gmail.com"
string(19) "2017-08-10 14:30:02"
string(10) "Roger Lugo"
int(200251)
Thanks Cate and Master Plvmber. Have a steam pro in BK that you’d recommend?
object(WP_User)#5175 (8) {
object(stdClass)#5169 (12) {
You need to fix the leaking pipe issue. If it’s a vent that’s leaking, that’s a systemic problem. Cate is right to suggest getting a seasoned steam pro to have a look at it. A regular plumber might not be the best choice to properly evaluate the system and make a determination for permanent repair.
cate | 6 years and 6 months ago
object(WP_User)#5172 (8) {
object(stdClass)#5170 (12) {
Perhaps a steam heating expert could weigh in here, but if you have hairline cracks, wonder if you could fix with plumber’s cement. OTOH this seems to imply the pipes are rotting and may need to be replaced — ideally not during heating season — before they burst and cause untold damage. Maybe it would be a good idea to have this evaluated by a steam heat expert you trust.
