replacing old radiators with modern ones
hello has anyone replaced their old radiators with one like these? https://usa.hudsonreed.com/delta-white-horizontal-single-slim-panel-designer-radiator-25-x-16-5-71164?gclid=EAIaIQobChMIje3Fxa3Q7QIVNAeICR2RCwtHEAQYASABEgJ6YfD_BwE&gclsrc=aw.ds
I was told this product will only work with closed loop hot water systems, how do I know if I have this or not?
thompson.molly99
28
object(WP_User)#5036 (8) {
  object(stdClass)#5024 (12) {
@masterplvmber, That is true, but my calculation, on a hot water system, was that BTU for BTU, it was less dollars to gets steel than Cast Iron(CI) rads. Also, FYI, if you buy them from England it’s cheaper than going through hudson reed. However with the covid situation in England, there could be delays right now. Regarding the BTUs for a big hunk of of metal, surface area is one element, but the finish on the radiator and its design also effect the EDR. But there’s other design considerations. A CI radiator is a high mass unit, and so the system will have to operate a long time to heat it up. With steam that’s fine, because all steam boilers are high mass, but in a hot water system I prefer a low mass boiler with low mass radiators. This makes it much easier to do thermostat setbacks and recoveries with smart thermostats, and also to balance the system.
scottresidentialgroupnyc | 5 years and 3 months ago
object(WP_User)#5035 (8) {
  object(stdClass)#5034 (12) {
    string(6) "201284"
    string(24) "scottresidentialgroupnyc"
    string(34) "$P$B1I5ZWrs1HLiFRDmEMg6glPcwrVHDp0"
    string(28) "scottresidentialgroupnyc-com"
    string(29) "scott@residentialgroupnyc.com"
    string(19) "2017-08-10 14:11:39"
  int(201284)
I replaced 6 old radiators in my house with new smaller modern ones from OSC in Bushwick https://ocsind.com
Master Plvmber | 5 years and 4 months ago
object(WP_User)#5031 (8) {
  object(stdClass)#5037 (12) {
We measure the output of a steam radiator by its surface area, a value expressed as equivalent direct radiation or EDR. Every radiator has an EDR rating published somewhere. To convert EDR to BTUs, multiply by 240 for steam and 170 for circulating hot water. The more surface area a radiator has, the more heat it will give off. That’s why a lot of those pretty wall hung radiators pale in comparison to the huge hunk of metal sitting under the window.
hkapstein | 5 years and 4 months ago
  object(stdClass)#5038 (12) {
I found the steel radiators supply more BTU per dollar than the cast iron ones, but which unit fits the space and how much BTU is needed and what the water temperature is all effect feasibility. They make multi column steel radiators that get more BTU per linear foot. If you have steam, steamradiators.com does supply units that work, and I had one once in the past and it worked fine. It was in a hallway where a slim unit was a priority. More expensive than cast iron though. For the steel hot water radiators it is cheaper I believe, though it may depend on the the all in cost, and how you need the system to perform.
If appearance is your concern and you have steam, you might look at getting standard cast irene slenderized radiators, and putting a nice cover over them. That way you’ll get any look you want and still have a cheap standard radiator.
evan | 5 years and 4 months ago
  object(stdClass)#5039 (12) {
    string(4) "5448"
    string(4) "evan"
    string(4) "evan"
    string(23) "eringeigersmith@mac.com"
    string(19) "2007-11-30 15:55:19"
    string(4) "evan"
  int(5448)
I’ve thought about this as well! We have single pipe/steam system radiators and this piqued my interest – a little Googling yielded this company, which seems to produce similarly streamlined looking units: https://steamradiators.com/
cate | 5 years and 4 months ago
object(WP_User)#5038 (8) {
  object(stdClass)#5031 (12) {
Interesting! I have always wondered about this. Nice looking radiators. Eman, do all radiators of this style have low BTUs? For example, the ultra-expensive Runtals? We have a tiny room with an oversize radiator and I have occasionally thought about replacing it with one of these. Or just a smaller regular radiator.
Guest User | 5 years and 4 months ago
string(6) "201692"
if you have a single pipe going to your radiator then you have a steam system and this will not work. If you have two pipes in every radiator , it is probably hot water. I had a client consider these for a movement but realized that the btus that the hudson reed units put out was so low compared to their cast iron that it was cost prohibitive
object(WP_User)#5042 (8) {
  object(stdClass)#5043 (12) {
Post a wide-shot picture of your boiler and I’ll tell you.
