Renewing Expired Plan Approval and Landmark No Effect Certificate?
Hello. I got plan approval and Landmark certification of no effect back in 2012 to build a deck on my 3 family. But I couldn’t get the money together to actually build the deck until now. The plan approval and Landmark certificate are now expired, but I had a structural engineer review my plans and he doesn’t see anything that has changed in the code since then, so I am anticipating that I should be able to get approval again. I got one bid from an expeditor to withdraw the existing Alt-3 for the deck and resubmit it and then renew the landmark permit, pull the permit, and do the inspection, for $6300. This seems high to me for a plan that I think should be easily approved. I am wondering if anyone has had luck getting expired plans and landmark certs approved again. I’m also wondering if I can do some of this — such as withdrawing existing Alt-3 — or even all of it myself. Alternately, can anyone recommend a more reasonable expeditor? Thanks!
pitythefool
in General Discussion 7 years ago
8
kassie319 | 7 years ago
object(WP_User)#5064 (8) {
  object(stdClass)#5052 (12) {
    string(6) "194226"
    string(9) "kassie319"
  int(194226)
I did this a while back, using Fellner to file it. TR1s included subsurface investigation (soil bore), subgrade inspection, cast in place concrete and several structural steel inspections – welding and bolting I think. A company called Twin Peaks did those that the applicant of record couldn’t do.
pitythefool | 7 years ago
object(WP_User)#5063 (8) {
  object(stdClass)#5062 (12) {
    string(5) "41142"
    string(11) "pitythefool"
    string(63) "$wp$2y$10$Eqp4ylepZjX3MKaub6d2EuyVv8NYoX41hWQDrVT54IFlmuLe8ALTq"
    string(23) "bliss.broyard@gmail.com"
    string(33) "http:///forums/users/pitythefool/"
    string(19) "2017-08-10 13:51:16"
  int(41142)
Thanks for this. I talked to Fellner and he was way more reasonable than the first expeditor I talked to, although he mentioned the potential need for a bunch of TR1 inspections, which I wasn’t anticipating. Not sure anyone commenting on this thread has filed a deck anytime recently, what TR1 inspections were required? This is just a standard 8 foot deck with supporting colums in poured concrete.
  object(stdClass)#5073 (12) {
AFAIK DOB forwards all applications from Historic Districts to LPC which will issue a no-effect certificate if the work is minor enough.
object(WP_User)#5031 (8) {
  object(stdClass)#5028 (12) {
    string(6) "194226"
  int(194226)
I second Fellner. Not sure if he will do Landmarks though. If you have drawings and and your structural consultant will sign and seal them you can do landmarks yourself.
object(WP_User)#5032 (8) {
  object(stdClass)#5030 (12) {
    string(5) "41142"
  int(41142)
Thank you!
a2chitect | 7 years ago
object(WP_User)#5028 (8) {
  object(stdClass)#5063 (12) {
    string(6) "180312"
    string(9) "a2chitect"
    string(34) "$P$BlPTq2Ur4fHb/lhfEWlLs3DgwqNgLK/"
    string(27) "matthew.h.mueller@gmail.com"
    string(19) "2017-08-10 13:44:18"
  int(180312)
Call Joseph Fellner at 718-398-2144. Very reasonable expeditor.
object(WP_User)#5030 (8) {
  object(stdClass)#5031 (12) {
    string(5) "41142"
  int(41142)
Thanks. I know the DOB isn’t a rational place, but I am hoping if it was approved before, the process will be a little easier and faster and cheaper…
mozeeatupu | 7 years ago
  object(stdClass)#5065 (12) {
    string(6) "176749"
    string(10) "mozeeatupu"
  int(176749)
Anything beyond two years requires re filing the job application. Basically start from scratch again.
