new under-stoop gate, smart-locks, new locusts
Are we done yet. What mike is saying will work. The latch only knob or lever catches and stops the gate from bouncing back. Yale bolt closes. Not really what you wanted but will work. You will have to build the Yale out on something. I used painted and shaped marine plywood once.
justinromeu26
26
arewedoneyet | 2 years and 5 months ago
object(WP_User)#5204 (8) {
  object(stdClass)#5192 (12) {
    string(6) "177175"
    string(12) "arewedoneyet"
    string(60) "1764158155:$generic$PmHW-7ILQ-A7BrfgVf69Sw4F6thntAV505zKCxgF"
  int(177175)
I was disappointed that no one had commented on the locust until this point.
I am worried about tolerances and making sure that this gate stays well enough aligned to keep the smart lock moving easily. One of the reasons I like the August is that I can easily remove it if it becomes problematic.
With regards to wear on the plastic interface piece on the August lock, I have 3D printed a replacement piece which fits the Marks mortise lock I have currently and it works well. My plan was to eventually make one in metal for the sake of wear. I’ve tested with a few pieces like this:
[IMG_4541](//muut.com/u/brownstoner/s3/:brownstoner:apG2:img_4541.jpeg.jpg)
mikehouse33 | 2 years and 5 months ago
object(WP_User)#5202 (8) {
  object(stdClass)#5205 (12) {
    string(6) "127250"
    string(11) "mikehouse33"
    string(34) "$P$BSYYs/jXi./wKcxhZWVCgpLA3Lx9MS1"
    string(21) "mikehouse33@gmail.com"
    string(19) "2017-08-10 13:54:27"
  int(127250)
Hi there I’ve just done this on a few houses and the Yale smart lock with traditional Baldwin or other typical mortise works well! Highly recommend piscipo ironworks, just send gaspar the lock and he will get it done!
object(WP_User)#5203 (8) {
  object(stdClass)#5206 (12) {
I must be miising something with the yale smart lock and a baldwin mortise.
Arewedoneyet, i am impressed with those parts. Truth is, your concerns are the same as mine and the reason i don’t offer to deal with gates is just what you say about tolerances. Steal is very unforgiving. We can manipulate wood any way we want.
  object(stdClass)#5207 (12) {
    string(6) "177175"
  int(177175)
Mikehouse33 which Yale lock did you use?
object(WP_User)#5206 (8) {
  object(stdClass)#5202 (12) {
Are we done yet, if you decide you want to use smart locks, ask me. I’ve installed the yale but did not talk about them here because you said you do not want one of the less reliable or bothersome ones.
In so far as what mikehouse suggests “yale smart locks with traditional baldwin….”: i had a job two years ago where i had to invesigate the entire yale line (and the august) and i could not find anything that works specifically with baldwin or marks. Mike may simply be suggesting a yale smart deadbolt in combination any other mortise lock below meaning you will end up with two separate locks. The yale deadbolts do not offer slam style locks which causes issues for you.
You can go with a yale tubular knobset that will slam but you face thickness issues. Also, i know already that you do not want that hideous looking blocky keypad/knob unit on your door. Am i correct?
I do not see too much difference between the yale smart locks and schlage from an installation pov but maybe readding about them can give you insight into performance.
object(WP_User)#5207 (8) {
  object(stdClass)#5203 (12) {
    string(6) "127250"
  int(127250)
Yes I used a Yale smart lock and a typical Schlage or Baldwin lever setup. Here is a photo with only the yale lock because we had to add the passage lever later. The lever helped keep the gate in alignment so the smart lock could work reliably. [35426964-4467-463A-A812-1DF3EC3E4ED8](//muut.com/u/brownstoner/s3/:brownstoner:q92v:354269644467463aa8121df3ec3e4ed8.jpeg.jpg)
