My house needs brick re-pointing and a coat of paint.
The facade of my house has peeling paint and is in desperate need of repointing (and potentially brick repair). I want to have it painted again after the brick has been fixed. Yes, I do understand that painted brick will require continual maintenance every 7-10 years to repaint — but I like the look. This leads me to two questions:
1) Does anyone have a recommendation for a good, reliable, reasonable mason or contractor for brick repointing, repair, and painting?
2) Does anyone know if the brick should be sealed before being painted? I know that it is typically sealed when exposing the brick.
Thank you in advance for any tips.
bklyn658
in General Discussion 6 years and 3 months ago
Arkady | 6 years and 3 months ago
string(1) "1" object(WP_User)#4911 (8) { ["data"]=> object(stdClass)#4892 (12) { ["ID"]=> string(5) "14677" ["user_login"]=> string(6) "Arkady" ["user_pass"]=> string(34) "$P$BSLpIhH1FLNbV2Qdpb/F67tu7brrgw1" ["user_nicename"]=> string(6) "Arkady" ["user_email"]=> string(20) "rkdillon@verizon.net" ["user_url"]=> string(21) "/forums/users/arkady/" ["user_registered"]=> string(19) "2008-08-04 21:50:38" ["user_activation_key"]=> string(20) "HL9P1Plx6tnm1l8GiJvd" ["user_status"]=> string(1) "0" ["display_name"]=> string(6) "Arkady" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(14677) ["caps"]=> array(2) { ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(2) { [0]=> string(10) "subscriber" [1]=> string(15) "bbp_participant" } ["allcaps"]=> array(4) { ["read"]=> bool(true) ["level_0"]=> bool(true) ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
In general, as you indicate you know, painting brick is ill-advised. Park Slope Brownstone does excellent pointing & refurbishment 646 554 4513 & would give you good advice about sealing.
