Mover recos for clawfoot tub
Hello,
Desperately seeking recommendations to move a large clawfoot tub (300lb 72”) from the parlor floor to the third floor. Our first two experience w a mover didn’t go so well. Help! Thanks!!
david-lewis
in General Discussion 7 years ago
david-lewis | 7 years ago
object(WP_User)#4998 (8) {
object(stdClass)#5010 (12) {
string(6) "194046"
string(11) "david-lewis"
string(34) "$P$BCiQAPKw3REIaDpuO4agfZoYKyyeuz."
string(20) "lewwin@earthlink.net"
string(19) "2024-02-23 13:19:38"
int(194046)
Dumbo Movers were exactly the ones I used and they couldn’t move it.
HouseNut | 7 years ago
object(WP_User)#4999 (8) {
object(stdClass)#5000 (12) {
string(5) "45965"
string(8) "HouseNut"
string(34) "$P$BhfkFH3s4gG9kG.gygxNT9BfagYY5p1"
string(8) "housenut"
string(23) "jsw_polemic@hotmail.com"
string(23) "/forums/users/housenut/"
int(45965)
Some companies will do it and others won’t. I used Dumbo Movers a couple of months ago to move a 6.5 ft. 375lb tub up one flight of tightly curved and steep stairs. I had been told by others it was not possible. 3 guys came, wrapped it in bubble wrap and moving quilts. Done.
object(WP_User)#5010 (8) {
object(stdClass)#5003 (12) {
string(6) "194046"
int(194046)
They can’t move it.
yudashasom | 7 years ago
object(stdClass)#4997 (12) {
The movers you’ve called can’t move it, or won’t move it? The reason I said it’s not a job for a mover is the cost/time/effort/liability is probably not worth it to them. Cast iron tubs, new and old, get moved around buildings everyday. Don’t overthink it. Find a construction crew working nearby, ask three guys if they want to make $50 each during lunch or after work. 300lbs is not that heavy. – it’s pretty much like moving a sofa bed.
GreenThinker | 7 years ago
object(WP_User)#5003 (8) {
object(stdClass)#4999 (12) {
string(5) "98498"
string(12) "GreenThinker"
string(12) "greenthinker"
int(98498)
P.S. You have to think in terms of sliding it, instead of expecting some guys to lift the thing and carry it up. Work smarter, not harder. Using 2 x 6 joists flat on the stairs, and some heavy duty rope, it should slide right up.
object(stdClass)#4996 (12) {
string(5) "98498"
int(98498)
I’d call a company that moves piano’s, they have some strong guys.
object(stdClass)#4995 (12) {
string(6) "194046"
int(194046)
To be clear, four movers can’t move it. I’m wondering if anyone has similar experience moving a tub or used a crane service. If so, recommendations are welcomed.
object(stdClass)#4969 (12) {
I think that moving a tub weighing hundreds of pounds might indeed be a job for a mover, depending on the size of the staircase.
object(WP_User)#5037 (8) {
object(stdClass)#5052 (12) {
It’s unclear what you are asking which is why no one answered.
Do you need a plumber? Or just someone to lug it? If you just need to move it then get a few friends over or find a neighborhood guy, or a contractor working on the block to give you a hand.
This isn’t really a job for a “mover.”
object(WP_User)#5036 (8) {
object(stdClass)#5038 (12) {
string(6) "194046"
int(194046)
Anyone?
