Large brownstone door glass pane disposal / rehousing
Hello. We just had the glass in our brownstone entry doors replaced. I’m unsure of how to dispose of the old panes. (I do not believe the replaced glass is original, btw…) Any suggestions? I’m more than glad to give them to any of my fellow forum members if any of you happen to be interested. Two panes measure approximately 72″ x 16″ and the other two are about 70″ x 16″ and they’re about 1/4″ thick.
Thanks,
Frank
fmb78
in General Discussion 7 months ago
bartonlewis1 | 6 months ago
object(WP_User)#5064 (8) {
object(stdClass)#5124 (12) {
string(6) "217597"
string(12) "bartonlewis1"
string(63) "$wp$2y$10$UpU30WjIAHbAa.hBagWeA.15.YHeicru5aC0F8Y/yqxrEtZ56kRfC"
string(17) "brtnlws@gmail.com"
string(19) "2024-09-18 14:58:33"
int(217597)
I posted here a few weeks ago asking for a recommendation for replacing the glass in my front door but never got an answer. Can you share who replaced the glass for you? It would be greatly appreciated! Thanks.
opoddubnaya.bootsoft | 6 months ago
object(WP_User)#5063 (8) {
object(stdClass)#5062 (12) {
string(6) "194931"
string(20) "opoddubnaya.bootsoft"
string(34) "$P$B0KLn0wD06yqfoNsYcAPGW5PMKxaT71"
string(20) "opoddubnaya-bootsoft"
string(30) "opoddubnaya.bootsoft@gmail.com"
string(19) "2017-08-10 14:11:36"
string(17) "Olga Pod Olga Pod"
int(194931)
No, we are good. this is not the case.
Brownstone Home Inspection | 6 months ago
object(WP_User)#5065 (8) {
object(stdClass)#5066 (12) {
string(6) "191038"
int(191038)
be careful putting these in newer installations. check the state and city laws on where safety glass must be used. on or around doors must be safety glass. Olga, if you are near doors, you have to be careful. if a visitor goes through a glass pane on a newer install, where safety glass should be, you can have problems. if someone got hurt, i mean. check the codes.
object(WP_User)#5055 (8) {
object(stdClass)#5067 (12) {
string(6) "194931"
int(194931)
We will happily take it to reuse as a second set of the doors for our glass enclosed porch that we are currently renovating. the measurements ( thank you for posting them!) are exactly what would feet as glass panels if we make a frame.
We need 3, and the 4th we could reuse as a coldframe cover.
But we will be away till next weekend.
