Door entry handles
Thank you, Steve. Funny you should mention because we’ve had that exact same problem also.
cate
22
Besides the obvious big box stores, where can one go to see in person different front door entry sets/handles? Or a place I might be able to find an antique one ?
I’d like to pair this with the Nest x Yale lock… anyone have any experience w this lock?
Elegance in Hardware, OTG (for vintage/antique), Rejuvenation (repro), Simon’s Hardware, Warshaw Hardware. I would advise against trying to go the antique route on your own; it becomes very hard to match locks with the knobs/handles. You’ll be calling Steve again. Charleston Hardware online has great repro items and you can buy a whole set there.
cate | 4 years and 11 months ago
object(WP_User)#5243 (8) {
object(stdClass)#5041 (12) {
House of Antique hardware has pretty standard repros. Can google salvage to find antique ones.
Lurker | 4 years and 11 months ago
object(WP_User)#5073 (8) {
object(stdClass)#5042 (12) {
string(6) "113126"
string(6) "Lurker"
string(6) "lurker"
string(6) "Lurker"
int(113126)
nest yale lock is excellent. There are lots of great options now. it’s slightly on the big side but is quite nice.
Good one Cate! There is also Van Dykes, Vintage Hardware & Lighting and Historic House Parts. I didn’t post too many online sites as OP said she wanted to ‘see’. I find online is easier/faster and sometimes cheaper. Unless one is investing in hardware that you need to see in person, online is the way to go.
object(WP_User)#5078 (8) {
object(stdClass)#5077 (12) {
the house of antique hardware lock bodies are garbage. the product itself looks good though.
as jane said, matching bodies with lock plates is impossible. so what we do is find old lock plates with the skeleton key on the bottom. we clean the antique stuff up and then using the old knobs put them through the spindle hole on a new Marks Lock body. and then we bore a hole above the old plates for the cylinder. we can put any cylinder in. we do this for doors we rebuild and we do it for once off customers. the work takes about an afternoon including buffing and sourcing parts and install.
Here is a photo of one i did. I JUST DID THE BRASS WORK AND LOCK INSTALL, THE DEVELOPER’S TEAM DID THE LESS THAN PERFECT PAINT JOB AND WOOD WORK. [Antique lock set brass](//muut.com/u/brownstoner/s3/:brownstoner:xbYb:antiquelocksetbrass.jpeg.jpg)
we stock a lot of parts and retailers.
All we do are doors.
object(WP_User)#5246 (8) {
object(stdClass)#5247 (12) {
i just looked at the photo of that lockset again and thought, “putting that on those doors is like putting lipstick on a pig”.
Steve, looked at the photo and thought to myself ‘This looks beautiful but the door doesn’t look great.’
object(WP_User)#5043 (8) {
object(stdClass)#5046 (12) {
Wow, that’s a pretty nice tip steve.
cobblehillhome | 4 years and 11 months ago
object(WP_User)#5242 (8) {
object(stdClass)#5248 (12) {
string(6) "178978"
string(14) "cobblehillhome"
string(34) "$P$BOUeOqRDqhvYmYxMf8DsOr2vJ8Eigq0"
string(19) "joshpanas@gmail.com"
string(29) "/forums/users/cobblehillhome/"
int(178978)
Re: smart locks — We’re planning on installing smart deadbolt locks from Level. https://level.co/
(It’s buried on their site, but if you navigate to the Bolt page and scroll down to FAQ – Compatibility section, you’ll expand the question to access a Quiz to see if the Bolt will work for your door)
Love this JP, thanks for sharing. The deadbolt option is great as I don’t like the look of the lock itself.
object(WP_User)#5041 (8) {
object(stdClass)#5079 (12) {
string(6) "113126"
string(6) "Lurker"
string(6) "lurker"
string(6) "Lurker"
int(113126)
Hey JP I have experience with those. First, you can pick the lock easily. They have beautiful hardware, however to unlock your door you either need to enable geofencing,or rely on the touch scheme, or use the app which is a bit tedious and no easier than carrying a key. For the touch and geofencing to work you have to leave a zone of 800 feet from your home after locking it in order to be able to use touch to unlock it again–meaning if you pop outside to the corner or a neighbors or go to your car and come home or leave and then want to run back inside for something, you end up needing to get out your phone call up the app to unlock the door. And if you happen to leave your phone inside your house and lock the door, you are locked out (unless you carry the key). There are many better options. The ultraloq pro is excellent and much smaller than many models.
object(stdClass)#5244 (12) {
@lurker, just put the key under the doormat, problem solved.
object(WP_User)#5079 (8) {
object(stdClass)#5243 (12) {
Steve, are the House of Antique Hardware’s locks easy to pick or they break a lot or something else?
object(WP_User)#5244 (8) {
string(6) "178978"
int(178978)
@Lurker, thanks for that info! Very good to know. I’ll let my husband know about the security issues as he’s in charge of this project. I do wish Ultraloq Pro looked better…. We’re talking to two designers, who very much care about the aesthetic of their front door! 🙂 But safety is important! Thanks for sharing your insights.
Level is miles ahead of Ultraloq but both are ok design wise. https://august.com. If you want to look at some nice hardware: Katonah, Simons, Elegance or the Brass Center.
Thanks for all the tips. Has anyone ordered from Charleston? Their stuff looks gorgeous.
Steve! I personally like Charleston as they have period reproductions which are historically appropriate and you can avoid the hassle of finding matching parts from antique dealers. The latter is almost impossible to do.
