Best flooring for a finished basement?
Luxury Vinyl Tile (LVT)
agdipierro
in General Discussion 4 years and 5 months ago
42
arewedoneyet | 4 years and 5 months ago
object(WP_User)#5062 (8) {
object(stdClass)#5246 (12) {
string(6) "177175"
string(12) "arewedoneyet"
string(60) "1764158155:$generic$PmHW-7ILQ-A7BrfgVf69Sw4F6thntAV505zKCxgF"
int(177175)
We’re finishing a basement space and will add french drains inside and out as well as a dehumidifier in the ducts so that we can handle water that does enter and prevent mold. I’d rather it end up as overkill then have to add it after the fact or pay for repairs and damaged property.
stickerhappy | 4 years and 5 months ago
object(WP_User)#5262 (8) {
object(stdClass)#5063 (12) {
string(6) "100776"
string(12) "stickerhappy"
int(100776)
Arewedoneyet, what are you doing for your basement flooring?
object(WP_User)#5061 (8) {
object(stdClass)#5066 (12) {
string(6) "177175"
int(177175)
We’re talking LVP but haven’t finalized anything
object(stdClass)#5064 (12) {
string(6) "100776"
int(100776)
Is that purely for cost reasons?
Or is there another reason to go with LVP over tile?
object(WP_User)#5066 (8) {
object(stdClass)#5262 (12) {
string(6) "177175"
int(177175)
Cost and comfort – unless heated tile is cold and we don’t want to use radiant. I think it’s also easier/cheaper to repair LVP.
JohnHancock | 4 years and 5 months ago
object(WP_User)#5064 (8) {
object(stdClass)#5061 (12) {
string(5) "22067"
string(11) "JohnHancock"
int(22067)
It will grow mold….
object(stdClass)#5062 (12) {
string(6) "100776"
int(100776)
You mean the LVP will grow mold, not the tile right?
object(stdClass)#5254 (12) {
string(5) "22067"
int(22067)
Right
ceci | 4 years and 5 months ago
string(6) "177206"
string(4) "ceci"
string(4) "ceci"
string(4) "ceci"
int(177206)
Just a thought, how about some sturdy large
persian rugs?
hasibur.rahman07 | 4 years and 5 months ago
object(WP_User)#5254 (8) {
string(6) "193777"
string(16) "hasibur.rahman07"
string(16) "hasibur-rahman07"
int(193777)
Concrete floor. Can be tinted as well.
object(stdClass)#5272 (12) {
Persian rugs would only work if you had a place to hang them to dry after they get soaked.
object(WP_User)#5253 (8) {
string(6) "177206"
string(4) "ceci"
string(4) "ceci"
string(4) "ceci"
int(177206)
True, I blocked out , “occasionally gets water!!”
object(WP_User)#5264 (8) {
string(6) "177175"
int(177175)
Please correct me if I’m wrong but if water is allowed to get under the flooring, whether it’s vinyl or tile, and isn’t promptly dried mold will eventually grow. This means that two things have to happen. One, keep the water out, and two, dry everything quickly if water does get in. It’s the drying part I’m wondering about. We’ve always relied on drains and dehumidifiers but I’m assuming that waterproof flooring, whether vinyl or tile, will trap water better making it harder to dry. Maybe radiant heat is the answer and/or some kind of permeability between the moisture barrier and the actual flooring. Does anyone with more practical experience than I have any thoughts?
jimcornell55 | 4 years and 5 months ago
string(6) "204010"
string(12) "jimcornell55"
string(34) "$P$BA5hf9bFxDRiBtlPlaSjOe1wmJOly/."
string(21) "jimcornell55gmail-com"
string(22) "jimcornell55@gmail.com"
string(19) "2019-02-24 11:54:48"
string(11) "Jim Cornell"
int(204010)
Very difficult to dry when there is no air between the layers. You don’t want a gap between your floor and the slab or you want a floor that is permeable so any water can escape. Depending on the tile, it won’t allow water to get underneath it or if it’s porous, water will evaporate. What about epoxy or garage flooring that’s tightly adhered.
object(stdClass)#5253 (12) {
string(6) "100776"
int(100776)
Yeah I figured properly installed tile would leave no space for water to get under, right?
I wasn’t looking to do epoxy or garage flooring because I want it to feel a little more like a finished living space.
object(stdClass)#5256 (12) {
string(6) "193777"
int(193777)
Tile and epoxy are common choices. You will do well with tile and you can insulate it underneath.
Augustiner | 4 years and 5 months ago
Look for dmx 1-step underlayment e.g. on EBay for around $1 per sqf
It’s a semi-rigid moisture barrier that creates an air space for water to evaporate or even run off underneath the finished floor.
bawcnzvztvupor | 4 years and 5 months ago
object(WP_User)#5256 (8) {
string(6) "209699"
string(14) "bawcnzvztvupor"
string(34) "$P$B4JJOyHJd5kShn.3BfTha7zlb6HieK/"
string(25) "dragonfly526.kj@gmail.com"
string(19) "2024-07-06 01:11:01"
int(209699)
Choosing a flooring to install in your basement can be difficult with so many options being available. But I think the best type of flooring for basements is vinyl because they made of PVC making it durable and waterproof.
object(stdClass)#5257 (12) {
string(5) "22067"
int(22067)
