No records on file for conversion from oil to gas heat
Hi. I took a look at a nice house today. The owner said he had converted from oil to gas heating within the past two years. I checked nyc.gov and there are no records–checked for the Boiler Record, DEP boiler record, etc. Nothing. The house hasn’t had requested a permit in years. What, if anything, should be done by the current owner or the next owner? Thank you.
stephanie
in Building Code 13 years and 2 months ago
yte | 13 years and 2 months ago
object(WP_User)#5058 (8) {
object(stdClass)#5013 (12) {
string(6) "178442"
string(3) "yte"
string(34) "$P$B9i5tdNEVtfRwt9wvpHBRIxYwfhU1P1"
string(3) "yte"
string(31) "yeinhorn@oldhouseinspection.com"
string(18) "/forums/users/yte/"
string(19) "2017-08-10 14:02:33"
string(3) "yte"
int(178442)
Or eventuially when you do need to file for some plumbing/gas work, just include the boiler in the work type. You’ll have to do a gas integrity test no matter what, so why not. If this is a one or two family that’s easy. If it’s a multifamily it might require a more subsantial boiler filing (schedule C).
ellenlourie | 13 years and 2 months ago
object(WP_User)#5057 (8) {
object(stdClass)#5056 (12) {
Do nothing, what worst could happen? Nobody does any work legally anyway, so why bother.
eme1million | 13 years and 2 months ago
object(WP_User)#5053 (8) {
object(stdClass)#5059 (12) {
string(5) "38269"
string(11) "eme1million"
int(38269)
Yes, you will definitely end up in front of judge and probably be sent to jail. Your property will be seized and your children will be taken from you. Your friends will desert you will die a miserable death at Attica.
object(stdClass)#5060 (12) {
One day you will need to do gas work, lets say install gas drier or something else. Plumber will send application, and will list gas boiler as an existing appliance. Then you will get rejection from building department along with fine and order to appear in front of the judge, because there is no gas boiler on record for your house. But hey, everybody does it, isnt it? But does it make it legal?
daveinbedstuy | 13 years and 2 months ago
object(stdClass)#5061 (12) {
Not sure why this matters. All sorts of repairs/upgrades are done on brooklyn houses without permits. Doesn’t make it right but hey, that’s life. As long as you inspector says the boiler is OK, and there are no issues with the workmanship, you needn’t be concerned. Your mortgage company won’t care either.
