Water leak from my ceiling when it snows
I have a brownstone with a flat roof. Anytime it snows, I get a water leak where water starts dripping from my ceiling. I do have an attic crawl space and noticed that there is no insulation up there, so I think it’s a condensation problem between the heat of the house and the cold outside which is aided by the snow. I have run a few tests with running water with a garden hose and have pretty much ruled out a roof leak. This has been a reoccurring issue for the past 5 years. Does anyone have any idea what can possibly be my problem? The roof is 10 years old and both roofers I called said to just redo the roof (I felt they just wanted a roofing job) and they were both unsure if that would resolve the problem. Any suggestions would be gratefully appreciated.
mutley
in Roofing 5 years and 3 months ago
26
in Roofing 5 years and 2 months ago
object(WP_User)#5075 (8) {
object(stdClass)#5248 (12) {
Slimc,
Back in 2014 their email was:
msicontracting@hotmail.com
Who knows if they still use that hotmail address?
cate | 5 years and 2 months ago
object(WP_User)#5045 (8) {
object(stdClass)#5048 (12) {
Oh christinamove, that story! I can empathize. Sounds like everything we’ve done here. (Insert crying emoticon.)
object(stdClass)#5251 (12) {
I’ll look when I get home
slimc | 5 years and 2 months ago
object(WP_User)#5245 (8) {
object(stdClass)#5246 (12) {
string(6) "177080"
string(5) "slimc"
string(5) "slimc"
string(5) "slimc"
int(177080)
Bob Marvin, Do you have an email for M.S.I.?
SoSlope | 5 years and 3 months ago
object(WP_User)#5251 (8) {
object(stdClass)#5043 (12) {
string(5) "16781"
string(7) "SoSlope"
string(7) "SoSlope"
string(7) "SoSlope"
int(16781)
They sell the heated wire at Home Depot. It is ready to install with the plug already attached. It may be called something like “gutter deicing cable.”
object(stdClass)#5068 (12) {
Keep in mind to, that with old wood frame, they are ballon construction which means the wall units are assembled with long studs usually without fire stops, so the water can enter up top and travel down the inside, often on the wood siding itself.
christinamove | 5 years and 3 months ago
object(stdClass)#5046 (12) {
string(6) "184790"
string(13) "christinamove"
string(34) "$P$Bxxa3pH0rldpFM2eIKzwDedrKsQ4wQ0"
string(23) "christinamove@gmail.com"
string(19) "2017-08-10 13:55:25"
int(184790)
We went through a whole crazy thing on the back of our house (we have a timber frame house from 1901. We suffered leaks that came into the first floor ceiling. Knew it wasn’t the roof. Couldn’t figure out how the water was getting in. Tried numerous water tests. We thought, in the end, it was the siding. Halfway through the re-siding job I climb up to the roof to inspect the job at the roof/gutter and siding seam, I look over to the dark side of the chimney and notice a gaping split all the way down. (I had to lay down and look over from the neighbors side to see that vantage). $20,000 residing job not needed*. I didn’t find it before I had to call someone. The contractor didn’t catch it…in the end it was a $20 piece of flashing that fixed the leak.
I think the downspout is a smart thing to check, but also look at the vertical seams of your chimney (if you have one). Look from a vantage point that you may not have easy access to, such as your neighbors roof or yard. You may see something.
*It was good we re-sided because now we have modern insulation, sheathing and siding on those walls now.
object(stdClass)#5044 (12) {
One of my neighbors runs the heated cable down a downspout for the reason slope describes. I had exposed pipe in a building and had to wrap it with the product. Not sure how many kinds are on the market but the one we ordered could be purchaed by the foot and the cap for the end and plug were sold separately. I purchased mine at an industrial supply. This was years ago, but i know they still make it.
object(stdClass)#5241 (12) {
string(5) "16781"
string(7) "SoSlope"
string(7) "SoSlope"
string(7) "SoSlope"
int(16781)
One solution is to run a heated wire up your downspout (these are made to keep gutter free of ice). You can leave the wire in place and then just plug it in when you have a frozen downspout (or risk of a frozen downspout).
object(WP_User)#5044 (8) {
object(stdClass)#5245 (12) {
string(5) "16781"
string(7) "SoSlope"
string(7) "SoSlope"
string(7) "SoSlope"
int(16781)
Very unlikely that this is condensation. If it were, you would have the same leak when it is cold outside, but no snow since the cold air would also cause the same condensation. Check your downspout. The snow will melt when it is well below freezing, especially because you have no insulation (heat from the house will melt the snow). As the water runs down the downspout, however, it can refreeze, causing the melting snow to pool on the roof. This pooling can find ways into the house that ordinary, well-draining rain will not.
housepoor | 5 years and 3 months ago
object(WP_User)#5241 (8) {
string(5) "71781"
string(9) "housepoor"
int(71781)
I had a similar problem with leaks after it snowed. I thought it was leaky skylight flashing. But it turned out to be a pointing issue. The snow would melt down the side of the building extension, then freeze in place when it got cold at night. As the water melted again it seeped in between the bricks and leaks started to appear. A good pointing fixed the problem once and for all.
cate | 5 years and 3 months ago
object(stdClass)#5045 (12) {
Thank you so much, Urbandad, Bob Marvin and Hellobedstuy, this is great info and much appreciated.
nomorejunk
object(WP_User)#5250 (8) {
object(stdClass)#5256 (12) {
string(6) "195271"
string(10) "nomorejunk"
string(34) "$P$BEp2RKhgSQQMCbCHN4MWh350BxKlcg."
string(23) "nomorejunk111@gmail.com"
string(19) "2024-02-23 15:52:38"
string(33) "Junk Removal 111 Junk Removal 111"
int(195271)
I had the same issue this past weekend. Got on the roof and found a 4 inch layer of ice covering a quarter of the roof while the other end was covered in snow drifts. Spent the day chucking all of the snow and ice off the roof, which solved the problem (temporarily). Missing insulation in some spots caused the snow to melt and and then freeze at night near the drain. The solution for me will be to add insulation (and maybe replace the roof hatch) and then apply new layer of flashing cement to all of the seams and near the gutter like mentioned above when it warms up a bit.
string(1) "3" string(6) "202271"
I had both Greene and Premier look at my roof this summer and recommended a new layer of rolled membrane. I _think_ they’re both honest enough to patch flashing if that’s all that’s needed…in my case it was clear flashing just wasn’t going to cut it. I ended up going with Greene who did it for a bit cheaper. Was happy with their work and working with them so would recommend but expect Premier would have done similarly. When both were looking at the roof for the estimate, both paid special attention to the overlap at the rear gutter and the poor workmanship they wanted to correct with the new layer.. Good luck!
object(WP_User)#5257 (8) {
object(stdClass)#5258 (12) {
He also installed a Bilco hatch, which was a major improvement over the original wood one.
object(stdClass)#5242 (12) {
BTW Mohammad replaced what was likely the original 1899 copper gutter, which had been patched many times.
The roofer we in 2014 used was:
Mohammad Islam
M.S.I. Contracting Inc.
151-15 Bayside Avenue
Flushing, N.Y. 11354
Phone and Fax 718-961-4666
Here’s what they did, cut and pasted from their proposal:
1. Rear wall: We will remove the existing gutter from the upper roof and we will re-build the brick wall right below the gutter (four courses in three wythe width) with existing and new bricks. We will also re-build the section of the roof deck directly under the gutter.
2. We will install a new galvanized 6k flanged gutter over newly built roof deck.
3. Downspouts: We will install new 4” galvanized leader pipes to connect the upper roof and the extension roof to the house drain.
He came highly recommended by a neighbor and were quite knowledgeable and through. He was also quite pricey, but he solved the problem.
object(WP_User)#5240 (8) {
object(stdClass)#5249 (12) {
Ok op. I was waiting to hear your reply before continuing with this:
Mine leaked along the back wall when the gutters clogged. I fixed this myself by taking some karnak 19 flashing cement and a strip of fiberglass mesh tape, the wide one. I put down a 3 ” wide strip of karnak along the back edge of my roof and another 3″ into the gutter, filling any voids under the lip of the roof membrane. I then pressed the tape in to the karnak with a couple inches hanging over the edge and I went by again pushing the mesh down into the gutter and into the karnak. I then covered the seam with more karnak, pressing out any voids as I went. I never had the problem again. If you passed first grade finger painting, you can do this. The hardest thing about it is keeping the karnak off your clothing.
I am new to these roofs (2006). I was working in a house once that had the same problem and the customer asked if I knew what was wrong. I did not so I said call a roofer. He told them they needed a new roof and ripped the old one up and put one down, probably sealing the s eam along the back wall as he did. Maybe they needed a new roof but I suspect a 1 hour repair with $30 worth of materials would have fixed it.
mutley | 5 years and 3 months ago
string(6) "178134"
string(6) "mutley"
string(34) "$P$BR/Zrx2ObKmk7uHu3cJo0.oOdG1ZBA."
string(6) "mutley"
string(21) "landmark757@yahoo.com"
string(47) "http://www.brownstoner.com/forums/users/mutley/"
string(19) "2013-06-24 19:08:07"
string(20) "7MeQpMPJU7CitRK5qKDF"
string(6) "mutley"
int(178134)
Thank you for all your responses. Yes, it is the rear wall where the gutters are located. Right now there is too much ice over there in order for me to take a better look. I will have to enjoy the sweet sounds of water dripping into the pots for the next few days until I can get up there with safe conditions. If you have any roofers that you can recommend please feel free to reference. I would use Angie’s list or Home Advisor but whoever I pick (regardless of the rating) is always a dud. As they say in “The Bronx Tale” , if it weren’t for bad luck I would have no luck at all !
