Low water pressure
We have low water pressure on the top (3rd) floor of our brownstone and I’m wondering how much it should cost to install a pump to improve the pressure…Has anyone done this who can recommend a plumber? Thanks
orrsuz
in Plumbers and Plumbing 14 years and 1 month ago
amandar | 14 years and 1 month ago
object(WP_User)#5092 (8) {
  object(stdClass)#5145 (12) {
    string(6) "177246"
    string(7) "amandar"
    string(34) "$P$BD327yWCKr2wyFnGISvhKBCwa.Pzoc/"
    string(7) "amandar"
    string(21) "amandar8234@gmail.com"
    string(22) "/forums/users/amandar/"
    string(19) "2017-08-10 14:17:42"
    string(7) "amandar"
  int(177246)
We actually had the same exact issue in another house a while back and it turned out to be the valve on the city waterwain that was the issue, I guess they needed to install a bigger one.  We used Harris Water Main & Sewer who successfully resolved our problem
Master Plvmber | 14 years and 1 month ago
object(WP_User)#5093 (8) {
  object(stdClass)#5094 (12) {
Maybe you undersized your pipes, or over-installed on your water outlets.
orrsuz | 14 years and 1 month ago
object(WP_User)#5097 (8) {
  object(stdClass)#5091 (12) {
    string(5) "36374"
    string(6) "orrsuz"
    string(63) "$wp$2y$10$JSgf3z5FdW3DH0FDVjos/.OQUAleodgzYEdJ5qaTu4jar5yabMUyy"
    string(6) "orrsuz"
    string(19) "orr.susan@gmail.com"
    string(21) "/forums/users/orrsuz/"
    string(19) "2017-08-10 13:49:24"
    string(6) "orrsuz"
  int(36374)
Thanks – its not low just not great. We just installed new bathroom – including new pipes from basement – and for the body jets & shower it just deosn’t do the trick….
  object(stdClass)#5090 (12) {
You don’t want a pump in your 3-story brownstone. They make noise, stop working, need maintenance and just generally create an unpleasant environment unless you get one of the really, really expensive ones (like $5,000.00 off the shelf). Find out why you’ve got low water pressure and fix the piping.
