Replacing older gate lock
http://cdn.brownstoner.com/502d09e806cca-.jpg
I need to replace an older gate lock for our brownstone.
Currently there is so much “play” in the old metal spindles even when locked the handle can be turned to gain access. I had a quote this morning saying $495 and btw its not going to be the same size and we need to screw some brackets on to fit the current hole……wtf???
Anyone else come across this problem as i assume we arent the only one with this generation of handle/lock?
I was hoping it was just going to be replacing the internal spindles/parts etc.
deancollins
in Locksmith and Security 13 years and 8 months ago
11
bmlock | 11 years and 4 months ago
object(WP_User)#5156 (8) {
  object(stdClass)#5168 (12) {
    string(6) "184693"
    string(6) "bmlock"
    string(34) "$P$B/zmDHCj99z6QJIFAaL613yJ6f5r/E0"
    string(6) "bmlock"
    string(30) "boiselocksmithexpert@gmail.com"
    string(35) "http://www.24hourboiselocksmith.com"
    string(19) "2017-08-10 13:55:23"
    string(6) "bmlock"
  int(184693)
We use our local provider http://www.24hourboiselocksmith.com. They’ve always helped us out with our side gates and all of our decoritive locks.
jeffhordy | 12 years ago
object(WP_User)#5157 (8) {
  object(stdClass)#5158 (12) {
    string(6) "181726"
    string(9) "jeffhordy"
    string(34) "$P$BuIu39gTd05PAb2WfN8Os4s3.wKSyI/"
    string(21) "jeffhordy@outlook.com"
    string(19) "2017-08-10 13:45:20"
  int(181726)
I don’t know if your issue has been resolved as I didn’t see any of your comment about it. So if you’re still suffering. I got anther suggestion for [locksmith in Henderson NV](http://www.asaplocksmithhenderson.com/), might be they can sort out your issue.
ruben1 | 12 years ago
object(WP_User)#5195 (8) {
  object(stdClass)#5422 (12) {
    string(6) "181769"
    string(6) "ruben1"
    string(34) "$P$BY9yvtFSJuRukEAoHNKmo9YlNOjGmm/"
    string(6) "ruben1"
    string(22) "Anderssinn@outlook.com"
    string(19) "2017-08-10 13:46:14"
    string(6) "ruben1"
  int(181769)
Good to hear that you were able to get your gate fixed. I will need to send this information to a family member of mine who a bit of the same issue. Thanks for the recommending them.
amyalberts321 | 12 years ago
object(WP_User)#5138 (8) {
  object(stdClass)#5139 (12) {
    string(6) "181804"
    string(13) "amyalberts321"
    string(34) "$P$BvbKxPp/SlI91.wyI4pPTA2kaKtbt/."
    string(25) "amyalberts321@outlook.com"
  int(181804)
I live in Henderson, NV and [I use locksmith Henderson NV more often](http://www.locksmith-henderson.com/) as they are one of the best service providers in my area and I’m pretty satisfied from their services too.
jeffhordy | 12 years and 1 month ago
object(WP_User)#5140 (8) {
  object(stdClass)#5427 (12) {
    string(6) "181726"
  int(181726)
Well I might have the solution of your problem. I always use [Providence Locksmith](http://www.lockexpertri.com/) as I feel they are the best providers over here. Thy offered their services in multiple areas. See if they are also serving in your area.
herry | 12 years and 3 months ago
object(WP_User)#5139 (8) {
  object(stdClass)#5195 (12) {
    string(6) "181232"
    string(5) "herry"
    string(34) "$P$BfEXfqDI8inCLkPUYUd1FGBpyVxOw.1"
    string(5) "herry"
    string(20) "ijazgill52@gmail.com"
    string(19) "2017-08-10 13:44:17"
    string(5) "herry"
  int(181232)
you can absolutely rpely on their expertise in any lockout situation.Pop-A-Lock DC Locksmith are thoroughly trained at our high-tech training facility to provide you with top quality locksmith services.Try it [key duplication washington dc](http://www.dckeyslocksmith.com “duplicate key washington dc”)
deancollins | 13 years and 8 months ago
object(WP_User)#5427 (8) {
  object(stdClass)#5143 (12) {
    string(5) "25779"
    string(11) "deancollins"
  int(25779)
5th Avenue Keyshop
+1 (718) 768-8643
295 9th St
(between 4th Ave & 5th Ave)
Brooklyn, NY 11215
USA
  object(stdClass)#5138 (12) {
    string(5) "25779"
  int(25779)
Nicky turned up this morning just to do a quote after i’d received 2 quotes from other companies for up to $950 to replace/repair/fix problems we were having with these 50+ year old locks.
His answer was…..Nope no need to replace everything here, will just needs some new parts, i’ll charge you $85 + parts of $15
Shazaam 20-25 mins later (about 10 mins each lock problems solved, both working perfectly and he cleaned up after himself).
Cant reccomend Nicky enough, was happy to write that check out. Highly reccomend 5th Avenue Locksmith Keyshop.
etconstruction | 13 years and 8 months ago
object(WP_User)#5143 (8) {
    string(6) "178534"
    string(14) "etconstruction"
    string(34) "$P$BrK2t99BzSyIN.4otG6/qWFoy81Ewx1"
    string(28) "phoneetforyourhome@gmail.com"
    string(29) "/forums/users/etconstruction/"
  int(178534)
Edward Torres President of ET Construction Design & Glass Inc Business # 917 468 9468 Fax # 347 422 0121 Visit us @ www.Phoneetforyourhome.com
    string(5) "25779"
  int(25779)
great thanks, just spoke with them though cant get here until Monday but sounded more professional than some i’ve been trying to describe the problem to……
just wondering with the number of gates in the area someone must be making direct retrofits available…..
BobMarvin | 13 years and 8 months ago
  object(stdClass)#5428 (12) {
I’d suggest trying the locksmith on 9th Street just west of 5th Avenue. They,ve been in business since the ’20s and really know their stuff. However the price is still likely to be in the hundreds.
