Heat Pump Installation
Hello, we’d like to install a heat pump in our windowless guest room. Do you have any recommendations for models? Any good Mitsubishi ones? Also, do you know someone who is good and reasonably priced, who could install it? Thank you!
househunter
in Heating and Cooling 13 years ago
victor123 | 13 years ago
object(WP_User)#5176 (8) {
  object(stdClass)#5192 (12) {
    string(6) "176913"
    string(9) "victor123"
    string(34) "$P$BMnykjfxJ/rSVzPRuSy3SH773k7jht/"
    string(25) "manohar@plushmarketing.ca"
    string(50) "http://www.brownstoner.com/forums/users/victor123/"
  int(176913)
The most common type of heat pump is the air-source heat pump, which transfers heat between your house and the outside air. If you heat with electricity, a heat pump can trim the amount of electricity you use for heating by as much as 30% to 40%. High-efficiency heat pumps also dehumidify better than standard central air conditioners
