Mitsubishi H2i Heat Pump Does the Job in Brooklyn
thanks for posting this. look forward to updates.
deancollins
in Heating and Air Conditioning 10 years and 2 months ago
21
jjq | 10 years and 2 months ago
object(WP_User)#5219 (8) {
  object(stdClass)#5207 (12) {
    string(6) "176804"
    string(3) "jjq"
    string(3) "jjq"
    string(3) "jjq"
  int(176804)
Thanks for all comments. I will start another thread for performance and running cost info later today. Sleestack- I agree, the Mitsubishi nomenclature is confusing… Best as I can determine the CityMulti is an H2i system designed for commercial use because of its large size (BTUs not physical size.) It will operate at 100% efficiency (produce rated BTUs) at 0 degrees F, while the M-series (like we have installed) will only give 100% efficiency only down to 5 degrees F. I believe the CityMulti units also start at 60,000Btu and can connect to more than 6 air handlers out of the box. The top of the line M-Series Units can only connect up to 6 air handlers tops.
