What is the best produce to unclog a bathroom sink?
When I’m talking about a snake, I’m talking about a tool like this:
https://www.globalindustrial.com/p/plumbing/plumbing-tools/pipe-cleaners/power-spin-w-maxcore-cable-25-feet-l-x-1-4-inch-w
They make them for under 10 bucks, and up to thousands of dollars depending on this size and length and ease of use. I don’t see that having a problem getting down the ikea drain. However if you don’t have one, it may be easier to remove the drawers and open the trap. Honestly it’s not that hard, a bit annoying perhaps, but you can do it.
If the clog is in the trap, a drain opening agent like pequa might do the job. I myself use drano max gel. They’re all basic the same stuff, sodium hydroxide, a very alkali material that dissolves things. It’s not acidic, and doesn’t react with metal or plastic pipes. I like the gel because it’s heavier than water and will sink to the bottom of the trap even when there is water in the pipe. It may require more than one treatment to clear a stubborn clog, and you can also consider leaving it in the trap overnight. If that doesn’t work, you need to be aware of the possibility of getting exposed to drain cleaner if you are a pro opens the trap to clean it, so make sure you tell anyone who’s going to work on it that you did that.
hkapstein
24
MDR | 5 years and 3 months ago
object(WP_User)#5065 (8) {
object(stdClass)#5053 (12) {
string(6) "170560"
string(3) "MDR"
string(3) "mdr"
string(3) "MDR"
int(170560)
Sometimes a toilet plunger works great – I just used that on a kitchen sink and a plastic knife that had gotten in there popped out. I’ve used it for a bathroom sink but for that you have to cover the sink vent. (Usually a little slot or hole in the porcelain.) You can do that by holding a wet rag against it. Also make sure the drain is full of water. Once you do that push down the plunger slowly then draw up quickly and the blockage will likely be dislodged.
cate | 5 years and 3 months ago
object(WP_User)#5064 (8) {
object(stdClass)#5063 (12) {
I have been told that chemical drain openers tend to create holes in your pipes.
object(WP_User)#5066 (8) {
object(stdClass)#5067 (12) {
If it’s a wall hung sink might it be problematic to use a plunger?
object(WP_User)#5060 (8) {
object(stdClass)#5068 (12) {
Cate, correct. The overflow will vent the efforts of the plunger.
