Steam pipe vent that doesn’t rattle
The tallest steam pipe in our house that goes up through four floors has a vent on it that eventually rattles after replacing it. Is there a different type of vent we should be using here? This particular one has no radiators off the pipe earlier. [IMG_3137](//muut.com/u/brownstoner/s3/:brownstoner:3Sa3:img_3137.jpeg.jpg)
chipito
in General Discussion 2 years and 2 months ago
chipito | 2 years and 2 months ago
object(WP_User)#5170 (8) {
object(stdClass)#5198 (12) {
string(6) "179751"
string(7) "chipito"
string(63) "$wp$2y$10$JqZ3R2KoP46vGEkh2wfcxuAZYgn7RLhjzYg9onMHhlbD22hVsUYea"
string(7) "chipito"
string(19) "jcmcnamee@gmail.com"
string(29) "http:///forums/users/chipito/"
string(7) "chipito"
int(179751)
Oh sorry…to follow up just replacing the vent has been working well for a few days now.. I had an extra maid-o-mist size D (biggest) and it’s been working great. I just wasn’t sure if there’s a special type of vent to put on a terminating pipe vs a radiator. It’s a 1/8″ thread.
carasgaladhon | 2 years and 2 months ago
object(WP_User)#5171 (8) {
object(stdClass)#5172 (12) {
string(6) "191171"
string(13) "carasgaladhon"
string(34) "$P$BOdhIIaaNqvk4e4KB38rdosq8wl6Aa1"
string(23) "direct@lindnertribe.com"
string(19) "2024-02-22 16:58:53"
string(25) "Jane Lindner Jane Lindner"
int(191171)
What size and type of vent are you using? I would probably go with the largest vent you can get, and maybe even double up the vents. It’s probably working hard to remove a large volume of air, being the tallest pipe in the house. Start with a Gorton #D, maybe even a Gorton #1. https://www.gorton-valves.com/products
Wondering if you have a 1/8″ NPT thread on the port (typical for radiator mounted air valves) or a larger threaded port, like a main vent port.
I’m just an amateur but a big fan of Dan Holohan’s books. Check em out if you haven’t already. “We Got Steam Heat!” is a good starter, then you can also read “The Lost Art of Steam Heating.”
lkrshacmzcy | 2 years and 2 months ago
object(WP_User)#5198 (8) {
object(stdClass)#5175 (12) {
string(6) "209518"
string(11) "lkrshacmzcy"
int(209518)
How many times have you replaced this vent and had the same result?
object(stdClass)#5169 (12) {
string(6) "209518"
int(209518)
