Steam Boiler Needs Replacement in Crown Heights
The low water shut off failed and our steam boiler was ruined. We are in an old limestone townhouse. We need to fix our heating and interested in getting advice on how best to do that since the boiler was so damaged. We are open to and leaning towards keeping our steam system, but have been reading a lot about switching to hydronic or switching to ductless mini-splits (or other options advised). Though we believe we have a single pipe steam system currently and also want to make sure our heat functions well. We’re looking to get help quickly, and I am working from home on Friday 11/17/17 to try and find someone who is knowledgeable, provide a quote and then hire to fix this. We are realistic in how much this will cost and our budget for it (based on what I have researched at least). We are ready to start the project immediately once we find a knowledgeable professional who can advise us on our options and help select the best path forward. I’m happy to answer any additional questions as well but looking for referrals or self-nominated professionals who can help with the above. Thanks!
varrcpte
in General Discussion 8 years and 4 months ago
varrcpte | 8 years and 4 months ago
object(WP_User)#5037 (8) {
object(stdClass)#5025 (12) {
string(6) "209483"
string(8) "varrcpte"
string(34) "$P$BssmxRQECuF4LBuplB6cK8ZVYK72290"
string(22) "bethany.v007@gmail.com"
string(19) "2024-07-01 18:44:29"
int(209483)
Thanks all. We wound up using Aladdin and they were fantastic. We have a new steam boiler installed beautifully. I highly recommend Aladdin! We will use them again if we need.
eman134 | 8 years and 4 months ago
object(WP_User)#5036 (8) {
object(stdClass)#5035 (12) {
MP
I am pretty sure that it was a stickframe with an existing oversized boiler . Dean had contacted me to take a look, but i was in barcelona at the time. Probably a boiler plate replacement with no sizing calculation. To the OP you can contact me at errol832000@hotmail.com if you still need a bid on boiler work
Master Plvmber | 8 years and 4 months ago
object(WP_User)#5025 (8) {
object(stdClass)#5032 (12) {
Was this for a multi-family? Most 4-story Brooklyn townhouses use a Burnham IN 6 or possibly 7, or equivalent. Do you know what method he used to size the replacement boiler? Can you post a picture?
deanbh | 8 years and 4 months ago
object(stdClass)#5038 (12) {
string(5) "58589"
string(6) "deanbh"
string(6) "deanbh"
string(6) "deanbh"
int(58589)
We just replaced our Burnham IN8.
Carlo from Aurora did the work 718-235-4091
object(stdClass)#5039 (12) {
You’re in good hands with Aladdin. Good guys right there.
You won’t need to wait for permits to start this work, especially if you’re not replacing gas pipe before the boiler’s “appliance”, or gas shut off, valve.
We do lots of boiler replacements all year long and never without a proper EDR or Manual J calculation. [DSC_5369](//muut.com/u/brownstoner/s3/:brownstoner:j37r:dsc_5369.jpg.jpg)
decodeddreams | 8 years and 4 months ago
object(stdClass)#5040 (12) {
string(6) "192813"
string(13) "decodeddreams"
string(34) "$P$B7sSOjSPu36cYZyIFZeBYHhAUfPN9d1"
string(23) "decodeddreams@gmail.com"
string(19) "2024-02-23 10:20:46"
string(13) "Adam C Adam C"
int(192813)
I recommend you contact Liam at Hunter Mechanical huntermechl@gmail.com He is very capable. The question is whether or not he is available. There’s only one way to find out. Best of luck! Richard | Manhatta Architecture, P.C. http://www.manhatta.net
object(WP_User)#5039 (8) {
object(stdClass)#5037 (12) {
string(6) "192813"
int(192813)
igor.vishnevetsky | 8 years and 4 months ago
object(stdClass)#5041 (12) {
string(6) "197734"
string(17) "igor.vishnevetsky"
string(34) "$P$B/D2R3F/GMrTOka6738J/n308kzMPI/"
string(26) "igor-vishnevetskygmail-com"
string(27) "igor.vishnevetsky@gmail.com"
string(19) "2017-08-10 14:28:00"
string(17) "Igor Vishnevetsky"
int(197734)
If you’re going to replace the steam boiler, I’d recommend that you get someone to size the replacement. Most boilers are about 1.5 to 2 times oversized. Most contractors either go by existing or use a rule-of-thumb.
Changing to Hydronic should save about 30%-40% on fuel, but may not be easy or quick.
Good luck.
Lastly, in NYC, steam boilers should have an auxiliary (backup) LWCO…
string(6) "209483"
int(209483)
Thanks for this, I’ll reach out to Aladdin. I know it will take some time, but didn’t realize it was permitted so that is helpful.
Guest User | 8 years and 4 months ago
string(1) "3" string(6) "197519"
We are in the middle of doing this right now but we are putting in a new gas-fired steam boiler. We are using Aladdin Plumbing Corporation – they have been great at helping us get the best boiler and helped with permits and rebates from National Grid. Just so you know it takes a while (a few weeks) to get the permits for all of this.
