Skim coating recs
Hello! I’m looking for skim coating recommendations because the prices I’m getting vary wildly. I’m looking to do my parlor floor, which is around 900 sq ft and was hoping to keep it under 10K, maybe even closer to 7K. I’m not sure if that’s possible, but I’ve read messages on the board where people have gotten it done within that price range. Thanks!
Guest User | 6 years and 9 months ago
string(6) "196752"
Thank you so much! That’s more in my price range. I appreciate the name, Nuna09. Cate, do you have the info for the person you used? I’d like to get a few quotes. Thanks again!
2345bcde | 6 years and 9 months ago
object(WP_User)#5087 (8) {
  object(stdClass)#5085 (12) {
    string(6) "182176"
    string(8) "2345bcde"
  int(182176)
Cate is correct. It is crucial to use plaster weld and mesh, loose plaster should be removed and cracks should be dug out.. There should be very little sanding necessary at the end.
cate | 6 years and 9 months ago
object(WP_User)#5064 (8) {
  object(stdClass)#5065 (12) {
Be sure you use someone who specializes in plaster, not drywall, painting or general construction. They should use PlasterWeld, fiberglass mash, and folding scaffolding. Their work should be smooth and level and they should not need to do much or any sanding.
kingwleung | 6 years and 9 months ago
object(WP_User)#5051 (8) {
  object(stdClass)#5105 (12) {
    string(6) "198650"
    string(10) "kingwleung"
    string(34) "$P$BpMyU7n8ubxCOcCV3ki.NV89pSruQR0"
    string(19) "kingwleunggmail-com"
    string(20) "kingwleung@gmail.com"
    string(19) "2017-08-10 14:35:00"
    string(10) "King Leung"
  int(198650)
Between $3,500 to $6,500
I used a guy is very good in skim Coating , and he has a very good price if you talk with him and he can understand you
You can call him 646-512-1447, ELI, you can talk about price with him
object(WP_User)#5084 (8) {
  object(stdClass)#5057 (12) {
Maybe $3,000 to $5,000, depending on the height of the ceiling, if you’re not looking to do the ceilings or any fancy work? We did walls only in about 600 feet of a top floor apartment a few years ago for $2,300.
