Roofing Approach
The top floor of my brownstone appears to have a sagging beam at the ceiling. Should I call a roofer or a contractor? And… do you have any recommendations? Thanks!
mattieweiser1
in General Discussion 2 years and 9 months ago
justinromeu26 | 2 years and 9 months ago
object(WP_User)#4996 (8) {
  object(stdClass)#5021 (12) {
Also, do not let someone tell you the roof has to be replaced because of something like this (if it is a roof joist). It may have to be cut open but a lot of this can be managed from below (yes, either way the ceiling is getting open up).
I became a roof inspector to help people save roofs, not replace them.
object(WP_User)#4997 (8) {
  object(stdClass)#4998 (12) {
ok. this can go two ways. if you have a crawl space in the cock loft, it can be simply a ceiling joist. if you do not have a crawl space in the cock loft, it is probably a roofing joist/rafter.
if you have a crawl space and it is a ceiling joist, a regular contractor can do this. if it is a roofing member, you will need a roofer.
it sounds to me like you need a roofing inspection anyway and you need a contractor (inspector) who can look at this, know what is going on, and can advise you how to proceed.
I do not work for or with any roofing companies. i work only for homeowners and represent them and their interests only.
Steve
Haag Certified Low Slope Roof (Commercial) Inspector
CertainTeed Certified Master Low Slope (Commercial) Roof Installer
brownstonehomeinspection.com
trini73diva | 2 years and 9 months ago
object(WP_User)#5001 (8) {
  object(stdClass)#4995 (12) {
    string(6) "195447"
    string(11) "trini73diva"
    string(34) "$P$BhAm1xuOyPRr49hUhjwFX9Gczcc5/q."
    string(23) "dawnobie16.do@gmail.com"
    string(19) "2024-04-16 19:02:46"
    string(45) "1713294416:$P$BHbi6pRlVh.YPfv4mXVNSvH7eD4fwh0"
  int(195447)
If it’s the beam most likely a contractor would have to be called in
