Roof replacement or repair
Hi All. I am looking for a roofer that I can use to do an immediate repair and down the track get the roof replaced. The roof has gone spongy so I expect that that means there is some work to be done under it. I had a quote a couple of years back which didn’t seem too bad (somewhere around the $20,000 -$25000 mark I think) but then I realised that they were just putting a new layer over the old and I had second thoughts. Now just 2 years after patching it is leaking into the ceiling of the top apartment …again. Always seems to be around the rear drain. Anyway any thoughts or recommendations I would be very grateful.
Guest User | 5 years and 9 months ago
11
string(6) "201177"
We used Royal to entirely replace an incredibly poorly maintained roof and they did a very good job (although all told, it came to around $34K for a not particularly large roof because once they started they found most of the joists and boards were rotten and had to be replaced).
mqkglcxx | 5 years and 9 months ago
object(WP_User)#5013 (8) {
  object(stdClass)#5003 (12) {
    string(6) "208429"
    string(8) "mqkglcxx"
    string(34) "$P$Biy4.0yfLQmXea5W8/AnZmCOs26eza/"
    string(27) "gracianosanchez40@yahoo.com"
    string(19) "2024-06-12 16:00:06"
  int(208429)
Fabulous Roofing did work for us a few years ago and were incredible. The owner is Gino, (718) 415-0575.
object(WP_User)#5066 (8) {
  object(stdClass)#5065 (12) {
    string(6) "208429"
  int(208429)
string(6) "201855"
Thank you to all who replied. The brownstoner crowd are awesome!
string(6) "202080"
Call this number 718-669-8305. We will give you good price.
string(6) "202080"
cate | 5 years and 9 months ago
object(WP_User)#5071 (8) {
Adding only a layer to a flat roof about 20 x 55 plus mudroom should be around $6K.
string(6) "200749"
Did you talk to Royal Roofing – they might be able to do both. A new roof should cost 20-25 but that’s cost is for work that is more extensive than adding a layer.
string(6) "201855"
Does anyone know a handyman who does roof patching?
string(6) "201855"
Yes but probably too cheap for a new roof with proper repairs of whatever was causing the sponginess, but then again I have no reference point to know. He didn’t seem to want to go into a lot of detail or explanation and I got scared off because if its hard to have a conversation right at the beginning what hope do you have.
JohnHancock | 5 years and 9 months ago
object(WP_User)#5072 (8) {
  object(stdClass)#5078 (12) {
    string(5) "22067"
    string(11) "JohnHancock"
  int(22067)
Seems very expensive for just another lsyer on top
