roof insulation: "blown-in" vs. panels
@katiekeating sure. send me an email at degrawapartment {at} gmail {dot} com
helen40
27
winbrown | 3 years and 9 months ago
object(WP_User)#5048 (8) {
object(stdClass)#5071 (12) {
string(6) "189554"
string(8) "winbrown"
string(34) "$P$BL9oqvlsvUYA70KjAifMae.kZJRIZ3."
string(18) "winbrown@gmail.com"
string(19) "2022-03-07 18:39:02"
string(19) "Win Brown Win Brown"
int(189554)
Hi Brownstoners- We’re getting solar panels, and though Brooklyn Solar Works said the roof was good enough for them, it’s apparently 30 years old and we’re thinking better to give it a top-up now before the panels are installed since there’s an area on the entension below that needs to be repaired and the roofer will be out anyway. We also want to insulate the roof and while the roofer suggested blowing in insulation (he didn’t say with what) the contractor and architect are suggesting 4 x 8 flat panels of insulation and then another layer of tar paper (membrane?) on top. Any opinions on this? And idea of cost difference? Thanks!
object(stdClass)#5246 (12) {
Why not u I se both for a higher R value?
object(WP_User)#5249 (8) {
object(stdClass)#5046 (12) {
string(6) "189554"
int(189554)
Contractor said blown in insulation causes a bunch of problems down the line. Architect said it doesn’t insulate as well.
object(stdClass)#5242 (12) {
FWIW I had insulation blown in back in the mid-70s. No problems so far. You do need to vent the cockloft to prevent condensation.
object(WP_User)#5244 (8) {
object(stdClass)#5245 (12) {
Ok, so if you have to vent the cockloft to use blown in, why would you use both? The panels won’t add any value with a vented cockloft. Its one or the other.
We used 3″ think (i think 3) panels on a commercial roof. I have heard other roofers suggest panels as well in commercial and last night i would have said that MUST be the way to go. Then it dawned on me that panels were our only option as we did not have ceilings that can support blown in.
In most conversations i have heard, i hear people grumble about potential issues with blown in. Settling is a word that comes to mind. Without any first hand experience to go by, if it were my house, i would use the panels.
Make sure all parties know solar is going on that roof if you use the panels. The panels are not solid like wood but something like celotex with a little give and i have no idea how heavy solar is nor how wide the pads they rest on are (to disperse load) and how they secure all of this to the roof. You want to ask the question to be sure the panel will not give under the weight of the solar and allow the support for the solar to puncture the roof membrane. I know, the question sounds stupid, but when you have 2 or 3 different trades or specialists on a building, you cant assume they know that solar is going down. I assume if the architect is spearheading this entire thing, that person knows what they are doing and would not suggest panels if they did not think they can support the weight but just ask to be sure.
Always ask questions about things like this. With you being a homeowner, so long as you are not driving them crazy with questions all the time, they will think you are really smart for asking. If they cannot answer the question, that makes you smarter than them just for thinking about it. And when you are spending a lot of money do not accept these for an answer: ” i think” or “you should be ok”; people have KNOW. no guessing.
You could probably find the answer to the question i just posed on google and i might look later and report back. I did not look it up and state it here because i always speak from experience but more than that i want readers on here to learn how to “manage” their projects and the contractors the way pros do and that includes not assuming that others have thought of everything.
kassie319 | 3 years and 9 months ago
object(WP_User)#5242 (8) {
object(stdClass)#5250 (12) {
string(6) "194226"
string(9) "kassie319"
int(194226)
I’d ask the architect if he’s ok with the additional load of the rigid panels which will need a a recovery board over the top of them (eg 1/2″ cement board) and the new membrane. I put a new membrane on my roof a few years back and a structural engineer friend told me it should be the last time I do that as there were already 4 old membranes on the roof.
object(stdClass)#5047 (12) {
See what happens when we begin asking questions?
The trick in this business is not to have all the answers but to know what questions to ask. And who to ask-
object(stdClass)#5255 (12) {
“The panels won’t add any value with a vented cockloft”
Thanks Steve—I didn’t think of that, but it’s obvious in hindsight.
object(WP_User)#5252 (8) {
object(stdClass)#5243 (12) {
The ONLY reason i caught that bob was i get people call me and ask me to insulate their doors and they’ll have a mail slot on them. Same kind of thing, sort of.
MDR | 3 years and 9 months ago
object(WP_User)#5255 (8) {
string(6) "170560"
string(3) "MDR"
string(3) "mdr"
string(3) "MDR"
int(170560)
Definitely add the rigid insulation. This will be continuous and much more effective since it is not interrupted by framing like the blown-in insulation.
object(WP_User)#5243 (8) {
object(stdClass)#5249 (12) {
string(6) "189554"
int(189554)
OK, great, thanks for the confirmation. Is this something that’s done by the roofer or is it a separate job? Also, any idea how much something like this costs on an approx. 20×50 roof?
object(stdClass)#5248 (12) {
The rigid foam is the roofer’s job.
sue.alexander123 | 3 years and 9 months ago
string(6) "189793"
string(16) "sue.alexander123"
string(34) "$P$BbLOIPTmWfP7Grk0yHIklWPht/S/Rr/"
string(16) "sue-alexander123"
string(26) "sue.alexander123@gmail.com"
string(19) "2022-05-26 22:32:00"
string(27) "sue alexander sue alexander"
int(189793)
I have blown as well and not issues ever! 9 years old
asaph718936 | 3 years and 9 months ago
object(WP_User)#5248 (8) {
string(6) "189794"
string(11) "asaph718936"
string(34) "$P$Bdxg9F71UtRThGP2zABcHOSS98xD/T/"
string(24) "asaphlarell648@gmail.com"
string(19) "2024-02-22 16:46:49"
string(25) "Asaph Larell Asaph Larell"
int(189794)
I did blown in my house many years ago and no issues. If I remember correct, it was also less expensive!
object(stdClass)#5259 (12) {
It seems to me that rigid foam makes the most sense if you’re also having a new roof installed and blown in insulation is the w way to go if you don’t need a new roof.
object(WP_User)#5253 (8) {
object(stdClass)#5254 (12) {
string(6) "189554"
int(189554)
Yeah – we’re in this funny space of the roof is looking really good, BUT it’s 30(?) years old. We’re getting solar installed so don’t want to deal with a roof issue 10 years from now and are trying to prevent future problems. All that and nothing seems to currently be insulated.
object(WP_User)#5259 (8) {
Ok, i have a neighbor who came to me looking for a roofer. He has solar. I went to a roofer i am friends with (i do not recommend him on this board for a variety of reasons). I told the roofer my neighbor has solar. He said “i will not touch anything with solar on it”.
Also, if you are new to this house and the roof was painted just before you bought the house, it might simply “look” good. That paint can hide uv worn membrane and other damage or someone can spot treat damage and cover it with paint. I am saying this to you because you seem to know what you have to do – don’t waiver on this, go with your gut.
I am not a roofer. I have inspected, maintained, patched, and sourced and managed large scale roofing projects since 1990. Before college and as early as 1980, i used to work for a company who did roofing and i sold roofing jobs to homeowners.
deancollins | 3 years and 9 months ago
object(WP_User)#5254 (8) {
string(5) "25779"
string(11) "deancollins"
int(25779)
We had 4″ insulation panels installed on our roof at 135 Henry…..before a new membrane was installed (about 8+ years ago??) can not recommend it enough.
Apart from it took forever to find a roofer who knew what they were doing/had used this product before (everyone wanted to install intra rafter material eg batts or blow in loose material-however i knew the benefits of external “above rafter insulation” from living overseas which is why i wanted that style) i highly reccomend it.
This with the addition we have cross ventilation (eg windows facing both east and west) means that we rarely have to run our AC….maybe 10-20 days a year at most…..compared to the noise and racket from our neighbors……i think this was a good choice to make.
object(WP_User)#5047 (8) {
object(stdClass)#5253 (12) {
So considering what dean collins is saying and my experience, i suspect the panels are more a commercial thing. Eagle roofing is someone i once got a quote from to do a job in manhattan using foam panels.
