Restoring coal burning fireplaces in 4 story townhouse
Neogrec, I think you could possibly remove the damper and a portion of the smoke shelf as needed working from inside the hearth, add a stainless steel liner and transition to the hearth thus eliminating the need for the smoke shelf. You could also do this by opening a hole at the mantle level, this would also allow you to infill between the existing smoke box and new flue. (Image on the right below) I would also add a rooftop draft inducer as well.
I do have a wood stove at an upstate property, it is fun to use and easy to clean, but probably not aesthetically correct for a historic Brooklyn home.
restorationcontractor
in General Discussion 5 years and 10 months ago
20
