Replacing etched glass panels in pocket door? Asking for my regretful 16 year old son!
When demonstrating a tennis swing, my son accidentally put his elbow through one of the etched glass panels in the original pocket door of our 1870 brownstone. Surely someone in NYC can replicate it. Anyone have a source?
pitythefool
in General Discussion 6 months ago
cate | 6 months ago
object(WP_User)#5220 (8) {
  object(stdClass)#5175 (12) {
That’s great to know, davidjonson. Thank you!
davidjonson | 6 months ago
object(WP_User)#5218 (8) {
  object(stdClass)#5221 (12) {
    string(6) "228997"
    string(11) "davidjonson"
    string(63) "$wp$2y$10$zbuT54s.MuKlwP5EFcEKMuviO3ZrJTJYCgw3jYQ5jsjceBx/tiUCO"
    string(29) "spam+davidjonson986@gmail.com"
    string(19) "2025-10-30 18:39:26"
  int(228997)
    ["bbp_blocked"]=>
    string(11) "bbp_blocked"
    ["bbp_blocked"]=>
Oh no accidents happen! You might try Franklin Glass & Mirror or Big Apple Glass in NYC. Both do custom glass work and can often match old etched panels pretty closely if you bring a photo or fragment. Also, some architectural salvage shops like Olde Good Things sometimes have vintage etched glass that could be a great match for your brownstone’s style. Good luck — it’s definitely fixable!
cate | 6 months ago
object(WP_User)#5219 (8) {
  object(stdClass)#5222 (12) {
Thanks, Steve, for the resources. I’d like to say to the homeowner please don’t trash the original beauties to match an inferior new one. That would be very unfortunate. The new one may not match exactly and doesn’t have to. You could also replace the broken panel with clear glass, opaque glass, swirly colored glass, and textured glass. If you still have sizable pieces of the broken original, a stained glass specialist could do insert a patch of clear glass. Many options.
Brownstone Home Inspection | 6 months ago
  object(stdClass)#5223 (12) {
    string(6) "191038"
  int(191038)
Bear glass down by Greenwood Cemetery.
or Rita on like Cooper Ave in Middle Village/Glendale, Queens. cell: 914-469 7276.
old glass may not match. colors will be different. so redo all of them.
cate | 6 months ago
object(WP_User)#5222 (8) {
  object(stdClass)#5218 (12) {
There are glass places around Brooklyn that do etching. Whether or not it is the same type and will look the same as the original is a question. I have heard there is a building supply in Sunset Park supplying glass and, IIRC, higher end wood for cabinetry type applications that does etching. I believe you will have to bring them the design you want on paper or in an electronic file. Some etching is cut glass, some uses a film, some is done with acid. Whatever method is used, the etched glass may look more blue and cold than the antique, possibly because the glass is clean and not covered in years of patina.
