Replace Sewer line inside cellar
The flooding caused by Ida cracked and damaged the concrete slab in my cellar right above the sewer pipe. This exposed the sewer line which was buried and there is a crack at the top of the sewer pipe.
So Brownstoners who would you recommend to repair this? Will any licensed plumber be able to do this? Do they need a permit to excavate and remove the pipe?
Thanks!
Guest User | 4 years and 5 months ago
18
string(6) "201992"
thanks!
lkrshacmzcy | 4 years and 5 months ago
object(WP_User)#5000 (8) {
  object(stdClass)#5002 (12) {
    string(6) "209518"
    string(11) "lkrshacmzcy"
  int(209518)
Petri Plumbing & Heating Inc.
718-748-1254
object(WP_User)#4973 (8) {
  object(stdClass)#4974 (12) {
    string(6) "209518"
  int(209518)
718-748-1254
string(6) "201992"
What is your company called?
I would like to get an estimate so I know what to expect. Thanks!
object(WP_User)#4967 (8) {
  object(stdClass)#4966 (12) {
    string(6) "209518"
  int(209518)
There are too many factors to say that without seeing it. Our company always comes out first to see work; it is the only way to set appropriate expectations and even then things can change.
object(WP_User)#5049 (8) {
  object(stdClass)#5004 (12) {
    string(6) "209518"
  int(209518)
slimc | 4 years and 5 months ago
object(WP_User)#4966 (8) {
  object(stdClass)#4968 (12) {
    string(6) "177080"
    string(5) "slimc"
    string(5) "slimc"
    string(5) "slimc"
  int(177080)
What’s the price range for the replacement described above? 20 feet of sewer pipe with permit, done same day?
object(WP_User)#5004 (8) {
  object(stdClass)#4967 (12) {
    string(6) "209518"
  int(209518)
For the record, most Plumbing companies can get this done. Our company would even offer to do it same day as long as it is in the morning.
  object(stdClass)#4965 (12) {
    string(6) "209518"
  int(209518)
    string(6) "209518"
  int(209518)
You can file a standard LAA permit. It only takes about an hour to file and the inspection is scheduled instead of given; they also rarely show up. Some Plumbers may not file it and say do not worry. I would say you will likely have a Plumbing truck parked outside your house for some hours to get this done; on the off chance a neighbor calls it in or a DOB is driving by they could stop in and issue you a fine. For context: our company is about $650 for a Non-Gas LAA but a WOP Fine is about $10,000
object(WP_User)#4965 (8) {
    string(6) "209518"
  int(209518)
colonialrevival | 4 years and 5 months ago
  object(stdClass)#5049 (12) {
    string(6) "195334"
    string(15) "colonialrevival"
  int(195334)
You have one master plumber already replying to you on this thread, below my reply :). I’ll note I did mistake my experience of replacing these lines—where a permit wasn’t needed—as the norm. Chris who knows far more about plumbing than I ever will has clearly stated it is not the case. Sorry for the mixup.
string(6) "201992"
will do.
object(WP_User)#4970 (8) {
  object(stdClass)#4958 (12) {
    string(6) "177080"
    string(5) "slimc"
    string(5) "slimc"
    string(5) "slimc"
  int(177080)
Following – let me know if you find someone and what the experience was like.
string(6) "201992"
Can you say more? It is probably about 20′ of line. This is from the trap to where it emerges from the ground and runs horizontally along the wall a few feet above the floor.
object(WP_User)#4963 (8) {
    string(6) "209518"
  int(209518)
….You need a permit to do this work. It depends on the amount of piping, but it will likely fall under the code for a permit.
  object(stdClass)#4964 (12) {
    string(6) "209518"
  int(209518)
object(WP_User)#4974 (8) {
  object(stdClass)#5003 (12) {
    string(6) "195334"
  int(195334)
No permit needed and most plumbers will do this. Once excavated it is a one day job.
