Rain Intensity, Water in Basement
I can’t take it anymore.
Over the last 3 years or so, every time we get a flash flood warning here in Brooklyn, my basement gets 10-20 gallons of water.
The main sewer pipe, which accepts the roof runoff, basically can not handle the water volume if we get an intense .5” over a 10 minute period… and the pipe fills up causing the drain at the foot of my exterior steps in the backyard to overflow into the basement.
The pipe has been cleaned, and there is no obstruction at the p-trap.
This has ONLY HAPPENED in the last few years, never during the 20+ years I’ve lived here.
I’ve even built a dry well which works well taking the garden runoff.. it’s simply the roof water causing a problem.
QUESTION
Are the rainstorms getting more intense?
Comments?
I’d like to avoid pumps or interior drain solutions.
If I put another 4” pipe in, essentially doubling the size of the path to the sewer, or replace with a 5” pipe… would this help?
jrs84o
23
jrs84o | 2 years and 8 months ago
object(WP_User)#5040 (8) {
object(stdClass)#5028 (12) {
string(6) "189678"
string(6) "jrs84o"
string(6) "jrs84o"
string(16) "jrs84o@gmail.com"
int(189678)
Yes… I’m afraid these are the comments I was hoping NOT to see, but… this is DIRECT evidence that something has happened to the climate over the last couple of years.
object(WP_User)#5039 (8) {
object(stdClass)#5038 (12) {
> @850mph
yes, it is called climate change.
object(WP_User)#5028 (8) {
object(stdClass)#5035 (12) {
string(6) "189678"
string(6) "jrs84o"
string(6) "jrs84o"
int(189678)
I should mention….
What most people seem to do here in Bay Ridge, is disconnect the downspout from the main sewer line and gravity push the roof runoff into the back yard.
Is this “Legit?”
Anyone branch off the roof runoff into a backyard path and main sewer path?
Thnx.
