Pocket Door as entry/exit
It is acceptable/normal for a pocket door to be used as the entry/exit into an apartment in a brownstone? i.e. Entry into the building hallway through the stoop door, and entry into the rental living area through sliding pocket doors (that do lock)
jimyjames.robert96
in General Discussion 2 years and 3 months ago
justinromeu26 | 2 years and 3 months ago
object(WP_User)#5136 (8) {
object(stdClass)#5172 (12) {
You cannot use insulated stop moldings and sweeps to block sound on pocket doors the way you can a hinged door. Also, many of these older doors have less sound deadening qualities, sliding or hinged – than modern doors.
jimyjames.robert96 | 2 years and 3 months ago
object(WP_User)#5135 (8) {
object(stdClass)#5130 (12) {
string(6) "190005"
string(18) "jimyjames.robert96"
string(34) "$P$B0JohxzsMmWluFNH3NFp6AUlR2U68X."
string(18) "jimyjames-robert96"
string(28) "jimyjames.robert96@gmail.com"
string(19) "2022-08-25 09:48:53"
string(21) "jimy james jimy james"
int(190005)
Thanks!
cate | 2 years and 3 months ago
object(WP_User)#5165 (8) {
object(stdClass)#5137 (12) {
I would suggest leaving the pocket doors alone. If you must convert them, I would suggest leaving the original pocket doors in the pockets and building a temporary filler with door surround and single door, so they can be converted back again in the future should another owner wish to do so.
object(stdClass)#5138 (12) {
Our original pockets doors are pretty great for blocking sound, much more so than the converted pocket doors, which have issues and gaps. Presumably a regular single door fitting and working properly would be superior.
object(WP_User)#5130 (8) {
object(stdClass)#5139 (12) {
Sound travels through them more so than with regular doors and it is harder to seal them than would be a hinged door.
object(WP_User)#5138 (8) {
object(stdClass)#5165 (12) {
I think it’s acceptable and normal in small one- and two-family houses. It’s not as secure as a regular apartment building, of course, and the occupants must trust each other. Our house was built as a two-family this way, with pocket doors to the dining room on the garden floor and to the parlor on the parlor floor. The original apartment on the top floor has no front door, so to speak — when you’re on the top floor, you’re in the apartment. It’s very common for people to convert the doors to hinges but it has drawbacks: The doors take up too much room, aren’t stable, don’t look nice, still aren’t especially secure, and you may find over time the locks don’t even line up anymore.
Guest User | 2 years and 3 months ago
Is it a fire rated door?
xuytbjicwnofjdde | 2 years and 3 months ago
object(WP_User)#5140 (8) {
object(stdClass)#5141 (12) {
string(6) "209569"
string(16) "xuytbjicwnofjdde"
int(209569)
when you say that they do lock, do you mean self-closing as well? Isn’t that a requirement?
object(WP_User)#5142 (8) {
object(stdClass)#5143 (12) {
Usually the are convered to something on hinges.
