Parquet Border
So I’m thinking about installing an 1890s style parquet border in a room that dos not have original flooring. It seems it is common for them to come glued up and backed, so they won’t need to be top nailed. The topnailing is part of the look, so I’m wondering if I should consider shooting finish nails into the product after it’s installed. Will the glued up version look funny, or too regular? Any opinions on whether to use 3/4″ or 5/16th peices? Anyone done this? What do you think?
Urbandad
hkapstein
26
object(WP_User)#5247 (8) {
  object(stdClass)#4978 (12) {
I used a 16 guage on my kitchen. In pairs. It does not look bad but perhaps to 234bcd’s point, a 15 guage would look better. I bet the nails they used were about 15. Maybe smaller. The ones in this 1928 house are small.
object(WP_User)#5246 (8) {
  object(stdClass)#4973 (12) {
I was planning to use 15 gauge finish nails, you think they would not look right coming from an air gun?
2345bcde | 5 years and 3 months ago
object(WP_User)#4970 (8) {
  object(stdClass)#5249 (12) {
    string(6) "182176"
    string(8) "2345bcde"
  int(182176)
A brad from a nail gun is much thinner then the nails that were originally used. If you’re going to use brads you may as well glue it down. I’ve faced nailed down floors with hammer nails and a punch. They don’t look right when you use a brad gun.
object(WP_User)#4973 (8) {
  object(stdClass)#5247 (12) {
with respect to finishes. People working on old houses would be wise to stay away from Home Depot and Lowes. also, do not use contractors who shop in those places for anything more than drywall, plywood, screws and nails and if they are hanging drywall, they should not be finishing your woodwork. Home depot and lowes still carry the Bona and Varathane that 2345bcde is alluding to. Varathane is what i was using in 1995 (i refinished a stage on 57th street in 1995 with varathane) and i do not think it has changed since. the rest of the world has changed a lot since 1995 (all except that other guy who posts on here, he is still using Formbys).
Urbandad, the street shoe will come with just enough dye in it (it looks orange in the plastic jug) to tone the floor enough for a 19th century house with a little bit of 21st century brightness. if it is a little too light, and i would not make that decision until after the second coat, a couple of drops of orange tint will do it (the universal tints in the plastic tube at the paint stores work well in water base finis hes, otherwise Transtint). that’s what the pros do. if you start dropping dye into things, even a couple of drops, keep a recipe book. for a long time i did not and then i learned when people called me back to do more work. i did not yet keep a recipe book in 2012 when i did that staircase i posted the photo of and consequently if they called me back to do more work, i would be left guessing.
if we wish to work on old houses, we have to think out of the box. almost like an artist.
with respect to face nailing old floors. when i was a child growing up in a house built in 1947, i thought the T&G floors, those that were edge nailed, were old. then i grew up and moved to the city and learned about strip flooring. Strip flooring is the old flooring in this city and it predates the T&G. They began developing modern woodworking machinery in the brownstone period. this machinery allowed them to run continuous lengths of T&G (modern door making, cutting a continuous joint in the stile of the door and assembling the door around the panels grew out of this same technology and we see modern doors by about 1920). in my 1928 house, they still used strip flooring. strip flooring is face nailed. outside of modern adhesives, i know of no way to apply it.
they did put filler in the nail holes in the old floors. at least in the better houses. if you wish to fill the holes, i would do so after sanding with the 60 grit. if you wait until before 100 grit, you might not get all the filler out of the grain. when i fill holes in projects, i often seal the wood and fill after and then immediately wipe the filler off the work with a cloth. you can fill with a dyed epoxy (you will not find that a HD or lowes) after screening after the second coat. you have to work fast if you use the epoxy and wipe hard and fast.
  object(stdClass)#5248 (12) {
Why do you think it will look different if we use an air gun to face nail it?
  object(stdClass)#4970 (12) {
    string(6) "182176"
  int(182176)
If you want your floor to have the correct tone ( a sort of honey color ) you absolutely need to use a oil based poly. A water based poly will not look right because it has no color at all. Don’t shoot nails into the face it will not look like an old floor you will have to face nail it. If you want it to look old you have to do it they way it used to be done.
object(WP_User)#5248 (8) {
The product is made for commercial, high traffic retail. I get it at PC Hardwood Flooring. Its pricey – about a buck a gallon.
I thought about that color all day and I bet it was mohawk dark golden oak. I began keeping a book of colors and finishes used in ’14 just in case questions like this arise.
  object(stdClass)#5246 (12) {
Hmm interesting. I was going to say that’s a lot of color, it looks like shellac almost(just in the color). I think I may have to buy a sample of this product and try it out. To be fair though, it’s on stairs and not in a kitchen with stuff getting spilled on it, or an entryway getting dirt and snow on it. Where can I buy it?
I might have misspoken above, we may have applied stain under that top coat. I am looking at a floor here and the street shoe does not color it this much.
so urban dad, it sounds like you are the kind of person who appreciates the efforts of others so i took the liberty of contacting a customer and asking him to take some photos of a staircase i finished with Basic Coatings Street Shoe in 2012. the wood was not stained (we would have sanded it to 120 which is what i finish most wood to) and the finish went right on as it was out of the container; the orange tint is natural. it is not clear like the other water base finishes and like what cate alludes to. the finish is predictable and this is how it looked the day we finished it. also, the wood may very well be red oak, i cannot recall, and the finish managed to tone it all kind of even. and lastly, i called the customer and asked him if there had been any wear to the finish and this was his reply “none at all and that is surprising as we live near the beach”. it was my first use of the Basic Coatings product and i chose it for its durability, knowing the y lived by the beach.
[Stairs street shoe](//muut.com/u/brownstoner/s3/:brownstoner:KlBo:stairsstreetshoe.jpg.jpg) [Stairs II steet shoe](//muut.com/u/brownstoner/s3/:brownstoner:kxO0:stairsiisteetshoe.jpg.jpg)
Cate is correct but step away from the mass market product. They are ok and I used them from the mid nineties into the 2000’s but at some point I switched to Basic Coatings Street Shoe. I did a staircase with it in 2012 and so far as I know it looks brand new. Also as cate said, the oil can be unpredictable. It can go very dark which seems to be counter to what people want today.
cate | 5 years and 4 months ago
Here is my (limited) experience for what it is worth: We used four coats of high quality satin (not semi gloss) water based poly — applied properly and given adequate time to cure — and it has held up amazingly so far for 11 years. No issues at all. (The floors in the baths and kitchens are Marmoleum, but the stairs are not covered and the finish is still looking great.) It’s pretty great to use on soft pine subfloors because it *doesn’t* change the color in unpredictable ways like oil does. However, I once lived in an apartment with a pale oak floor refinished with water based poly and the floor drove me crazy because it was so light, too light for my taste. Last, the oil takes forever to cure and the fumes are toxic so oil does not seem like an option if anyone is living in the space.
hkapstein | 5 years and 4 months ago
  object(stdClass)#5250 (12) {
Thanks, I’ll talk to New York Hardwood Floors. Have a couple leads on the floor but I think if you like this guy he’s probably good.
Now regarding the oil vs waterborne, here is why I’m liking oil:
1. More durable. I’ve tested many water products, and they don’t last as long. They are less abrasion resistant, less water resistant, less chemical resistant, and when they fail they tend to fail more rapidly. The oil usually buys more time to do the refinishing before the wood starts to get damaged. This disadvantage applies even to the water based finishes with cross-linking claims that I have so far tried. I’ve had a wood floor in a kitchen with water based and man was that terrible. Typically a water base finish needs to be redone about twice as often as an oil based one in my experience.
2. Appearance. You can tint a water base to look amber, some of them look pretty good, but they don’t age the same as the oil based ones. This alone is probably not a deal breaker, but with certain materials it’s easier to get the right look with the oil product. Water based products create more grain raise which may or may not be a problem depending on the project.
3. Application. For a contractor, it’s probaby much easier to do 5 coats of water and be out of there than to do 3 coats of oil. But if it’s a DIY or a longer project, I prefer to do 3 coats of oil and be done than to build a water base finish. The water is so thin, that on many projects, I end up actually doing 10-12 coats of water-base poly to get a decent finish. More coats means more chances to mess something up. The water is easer to work with and clean up, but I actually find there’s more opportunities to get a bad result with the water products. I actually found myself prefering shellac sometimes, and that the durability of the shellac was not too much worse than the waterbase but the recoat time was much shorter.
I think a better product than water is the newer UV cured finishes. I would use this, but special equipment is needed, and only a few shops have them at this point. UV is more durable than oil, and easier to apply. It cures fully and instantly with no offgassing. I haven’t seen enough of these to comment on the appearance, but I think this product will be getting more popular.
stevecym | 5 years and 4 months ago
  object(stdClass)#5251 (12) {
urbandad, i’ve refinished scores of floors and for years resisted the newer products. but the water base stuff is so much easier. two coats in a day, low odor. easy clean up. if i did my floors in this house tomorrow, it would all be water based. if you tell me what your reservations are or wish to email me, i’d be glad to address them for you. if you can get around the same things that i had to get around as i made the transition, you will be happy.
go see the guy just outside lowe’s gate. he is a great help. i want to say his name is jack. the company i think is New York Hardwood Floors. He has been so helpful to me that he deserves the exposure here.
object(WP_User)#5250 (8) {
Thanks, I like the idea of white oak. Probably can save some $ by using the 5/16th inch material. I’m gonna just use oil based poly. It may not be around in 10-20 years when it need refinishing, but I’ll deal with that then. Probably will do UV finish if that happens.
object(WP_User)#5251 (8) {
not sure with flooring and you already may know but i think when i buy quarter sawn dimensional lumber, it is a full two times the price of plain sawn. i only use it when a customer asks for it.
if you want little color variation, go with white oak. i know that white oak can look a little bland under modern water base finishes, but you can either use a cheap water base floor finish and add a few drops of orange dye to it, just enough to see it tint a little or you can buy something like basic coatings street shoe which comes pre dyed to tint it over. i think Absco may also make pre tinted finish. we used the street shoe on our kitchen floor and its just a little lighter than oil base poly. i would say it is just right.
Interesting point. Since this is a new floor, I don’t need to match the existing. Now quarter sawn oak looks really nice. And while it’s more expensive, the cost seems minimal compared to the cost of labor on the project. But nonetheless, I’m not sure that’s the way to go. I’m thinking I want to get select pieces that don’t have a ton of color variation to make the floor look really nice. Using plain sawn might be fine if the boards look good, particularly since it will be only 1.5″ strips. But if it’s all cathedrals, maybe not.
not all floors use quarter sawn wood. and those that do get pricey.
Arkady | 5 years and 4 months ago
I fixed a few areas on mine & found that the important thing to get it to match was to use quarter-sawn wood.
