No gas stove connected in apartment?
We are going to be moving into an apartment that has a really old gas stove in there. Can we get rid of it and have nothing hooked up to that gas line or is that against any code or something? We are not removing or doing anything to the gas line, just disconnecting the current stove and turning off the gas valve behind it.
Guest User | 7 years and 2 months ago
daveinbedstuy | 7 years and 2 months ago
object(WP_User)#5056 (8) {
object(stdClass)#5003 (12) {
A question you should be posing to your landlord.
cate | 7 years and 2 months ago
object(WP_User)#5054 (8) {
object(stdClass)#5057 (12) {
Yes that’s right an electric stove needs a special 220 v outlet.
in General Discussion 7 years and 2 months ago
object(stdClass)#5066 (12) {
Are you planning to have no stove at all or to replace it with an electric range? If the latter, does your apartment have the 220V line that, I think, would be needed?
object(WP_User)#5062 (8) {
object(stdClass)#5061 (12) {
It’s not against code to not use a working gas line. Just be sure to use someone to disconnect the stove who knows what they are doing and can correctly turn off the gas valve and verify the valve is working and not leaking (all very simple if you know what you are doing). Also, if you are renting, obviously you will need to get your landlord’s permission first. Old stoves can be extremely heavy so you will need appliance movers — probably at least three guys if it is not on the first floor. If the stove is circa 1900 to 1950s, and it is not leaking, you may want to arrange to give it to someone who can use it or refurbish it. They are worth about $300 if not fixed up, but difficult to transport.
