Need someone for in wall speaker wiring and an ethernet jack
Hi-
I want to run speaker wire from my amp through the walls to the speaker location. I also want to pull a cable run up from the demarc point in my basement and install an ethernet jack upstairs.
Anyone have a good rec for someone to do this?
Thanks!
jaywhy
in General Discussion 6 years and 2 months ago
lkrshacmzcy | 6 years and 2 months ago
object(WP_User)#5049 (8) {
object(stdClass)#5037 (12) {
string(6) "209518"
string(11) "lkrshacmzcy"
int(209518)
Second the Low Voltage installer
object(WP_User)#5048 (8) {
object(stdClass)#5047 (12) {
string(6) "209518"
int(209518)
eperry60 | 6 years and 2 months ago
object(WP_User)#5044 (8) {
object(stdClass)#5050 (12) {
string(6) "193403"
string(8) "eperry60"
string(34) "$P$B1EqBoyWfiOoRiI2m/hd2cfj49eEkx1"
string(20) "newsum.e@comcast.net"
string(19) "2024-02-23 10:57:40"
int(193403)
I’d recommend you check the “Home Automation” listings under “Services” – link is at the top of the page. Any one of the companies there should be able to do what you’re asking.
mozeeatupu | 6 years and 2 months ago
object(WP_User)#5047 (8) {
object(stdClass)#5049 (12) {
string(6) "176749"
string(10) "mozeeatupu"
int(176749)
Prob just need a low voltage installer, someone who does alarms etc.
hkapstein | 6 years and 2 months ago
object(stdClass)#5051 (12) {
Either one is fine. It will be a cinch for an electrician to pull cables and that why I thought that could be good, but you need someone who knows how to make the cable terminations. Electricians likely do, but if not that person could be you with a few tools from Amazon. An IT type person could probably do it too. Either way I think this is a situation where you’d get a better price from “a guy” than a company. But you never know.
jaywhy | 6 years and 2 months ago
object(stdClass)#5052 (12) {
string(5) "20103"
string(6) "jaywhy"
string(6) "jaywhy"
string(22) "jordanfyoung@gmail.com"
string(19) "2017-08-10 13:58:25"
string(6) "jaywhy"
int(20103)
Thanks for the responses. @Murrayhill- The ethernet jack is for my primary wifi access point. For a variety of reasons I elected to put the demarc in the basement. As a stop gap I have the primary access point there and have additional access points on the upper floors. I want to get the primary point out out of the basement and onto the first floor, hence the need.
Would the consensus be an electrician over someone tech focused? I’m mostly concerned about them doing a good job pulling the cable and not making too much of a mess.
Thanks
stevecym | 6 years and 2 months ago
object(stdClass)#5053 (12) {
i am not sure someone who thinks of himself as an electrician (unlicensed or not) will be the person. i just don’t see a lot of electricians carrying the sort of tester used on these cables. more of an IT thing i think. (but yes, union electricians consider this in their trade; they learn it in training).
perhaps this, have some handy person pull the wire and you go to HD and buy the tool and tester to put the ends on. easy. i have done it but sometimes crossed wires (there are 16 of them i think) and hence the need for the tester. by the way, they have both cheap and more expensive testers for these, so not a lot of $ to do this yourself.
you tube must have a video on how to put the ends on-
object(WP_User)#5052 (8) {
object(stdClass)#5048 (12) {
Find an unlicensed electrician. I’m not going to post names, but ask around, they’re everywhere. A license would not be required for this.
nednedx
object(WP_User)#5015 (8) {
object(stdClass)#5062 (12) {
string(6) "191125"
string(7) "nednedx"
string(34) "$P$BAm0CsYxXsCATUIiYDRBp5317uuUn61"
string(7) "nednedx"
string(18) "Nedsterx@gmail.com"
string(19) "2024-02-22 16:58:26"
string(21) "NEDDIE Jay NEDDIE Jay"
int(191125)
Why not just go wireless. Check out eero for best coverage in a townhouse
