Need help with Runtal radiators.
Can hear the water filling all of the time. Not sure how to balance system or flow rate.
Guest User | 6 years and 2 months ago
nyc_sport | 6 years and 2 months ago
object(WP_User)#5008 (8) {
  object(stdClass)#5053 (12) {
    string(5) "39535"
    string(9) "nyc_sport"
    string(16) "btfraw@yahoo.com"
  int(39535)
Did this just happen? Do you have variable speed circulating pump? I had that issue when the heat first came on after a renovation (4 years ago) and it was solved by lowering the circulating pump speed. But that would not explain this issue surfacing in February.
hkapstein | 6 years and 2 months ago
object(WP_User)#5010 (8) {
  object(stdClass)#5007 (12) {
I suspect there is air in the system as well. First set the correct pressure at the boiler by adjusting the prv, then bleed a couple times.
lkrshacmzcy | 6 years and 2 months ago
object(WP_User)#5009 (8) {
  object(stdClass)#5006 (12) {
    string(6) "209518"
    string(11) "lkrshacmzcy"
  int(209518)
Did you install them or purchase the unit with them?
  object(stdClass)#4999 (12) {
    string(6) "209518"
  int(209518)
eman134 | 6 years and 2 months ago
  object(stdClass)#5005 (12) {
you have air in the system bleed the radiators
