Need boiler duct repaired/replaced
We’ve contacted several plumbers and HVAC companies and only found one that repairs ducts, but they don’t have time to repair ours. It vents 4 or 5 boilers so it will be a somewhat complex job to replace, if it can’t be repaired. There are holes in the duct, and it appears that someone attempted to cover some of the holes with plaster, but that doesn’t last. It’s approximately a 12′ in length. Hope someone on the forum can recommend an experienced company to do this work.
ilovestoops
in General Discussion 6 years and 6 months ago
ellenlourie | 6 years and 6 months ago
object(WP_User)#5010 (8) {
  object(stdClass)#5063 (12) {
Holes in the vent connector are sign of improper boiler operation. Get boilers and chimney checked as well.
Guest User | 6 years and 6 months ago
string(6) "201176"
HELLO , my name is jes Diaz, a Brooklyn handyman. I will be glad to provide you with my service.If you are having any problem with your chimney or the boiler breeching which is thet portion of metal ductwork that connects the boiler proper to the stack. Usually starting directly above or outboard the boiler exhaust.
Call me or email me to schedule a visual inspections,
Cell#3056762768 email. Jesusediaz23@gmail.com
IF IS ON MY HANDS THE JOB WILL BE DONE.
THANKS,
string(6) "201176"
THANKS,
Master Plvmber | 6 years and 6 months ago
object(WP_User)#5034 (8) {
  object(stdClass)#5032 (12) {
I think you’re talking about flue piping to the chimney. You need to call a chimney company and not a plumber.
