Moment Frame
Has anyone installed a moment frame at the rear of their house? 1. How long does it typically take to manufacture 2. Engineer is recommending one at the parlor level and one and the garden level since we will have an opening on both. 3. I’m nervous as it will take a long time to make and install and they also seem to run about 8k apiece. 4. We have an extension at the garden level and i assume the columns of the frame will need to go through it and then down to ground. Any recommendations for a good fabricator?
hasibur.rahman07
in General Discussion 7 years and 9 months ago
hasibur.rahman07 | 7 years and 9 months ago
object(WP_User)#5007 (8) {
  object(stdClass)#5028 (12) {
    string(6) "193777"
    string(16) "hasibur.rahman07"
    string(16) "hasibur-rahman07"
  int(193777)
Thank you! So helpful! I do usually let my GC handle the subcontracting but sometimes he has flaky subs. For example his plumber didn’t show up for weeks when we had that extreme cold spell and my HVAC wasn’t working. So I like to be prepared in case. Thanks again.
AnArchitect | 7 years and 9 months ago
object(WP_User)#5008 (8) {
  object(stdClass)#5009 (12) {
    string(5) "89402"
    string(11) "AnArchitect"
    string(34) "$P$B1nP7yyKJcLDOOq69fypmL4oqEIQUM."
    string(11) "anarchitect"
    string(24) "acortes@agenciegroup.com"
    string(26) "/forums/users/anarchitect/"
    string(19) "2017-08-10 14:36:11"
  int(89402)
Moment frames are effective albeit expensive. Generally that scope would be managed by the GC. I would suggest contacting Edgar Ramirez at Two Steel Fabrication: twosteelcorp@gmail
