ISO round wood newel for interior stairs
We thought we could salvage our very cool original round newel during our renovation but sadly that is not the case. I’m finding a lot of square newels out there. Anyone know where I can get a reasonably priced newel that looks somewhat like the attached image? [Newel](//muut.com/u/brownstoner/s3/:brownstoner:sliQ:newel.jpg.jpg)
jen-kg
in General Discussion 6 years and 5 months ago
16
jen-kg | 6 years and 3 months ago
object(WP_User)#5080 (8) {
  object(stdClass)#5068 (12) {
    string(6) "195100"
    string(6) "jen-kg"
    string(34) "$P$B0ltml71kFiEtxhvRCUVpjC0hnuiqh."
    string(6) "jen-kg"
    string(19) "keiserjen@yahoo.com"
    string(19) "2024-02-23 15:35:38"
  int(195100)
update – the stair guy thinks he may be able to use the original newel and add height at the bottom for the new stairst that are built to current code. We’re still waiting on the verdict. Thanks everyone for your ideas!
intheheights | 6 years and 4 months ago
object(WP_User)#5079 (8) {
  object(stdClass)#5078 (12) {
    string(5) "28666"
    string(12) "intheheights"
    string(24) "david.a.gilman@gmail.com"
    string(19) "2009-04-05 19:47:33"
  int(28666)
@mms2222 are you looking for newel still?
hkapstein | 6 years and 5 months ago
object(WP_User)#5068 (8) {
  object(stdClass)#5075 (12) {
Here’s another thought, you chould make a steeper transition piece for the railing. You don’t need a compliant railing unless the drop is more than 30 inches. Might look a little different from the original, but nothing will look perfect with such a high balustrade in my opinion, at least you’ll get to keep the original newel. The transition piece will probably be a lot less expensive than a new newel post.
cate | 6 years and 5 months ago
  object(stdClass)#5081 (12) {
Some good advice here. OP, your house is most likely circa 1840s/50s. The city’s dates for buildings before the late 1930s are usually wrong. Here’s an article about that, plus links to more articles about dating buildings. https://www.brownstoner.com/architecture/how-old-is-my-house-nyc-brooklyn-city-records/
stevecym | 6 years and 5 months ago
object(WP_User)#5082 (8) {
  object(stdClass)#5083 (12) {
34 sounds correct for rail height (it has been over 10 years since i have built a balustrade) but if the newel is going to be used as a landing newel, with a balustrade running back around to the wall above the stairs, the post will have to be about 42″ tall at minimum and taller with any decorative elements on top.
kind of the same with a starting newel.
i seem to recall ordering these in like 48 and 54″ heights and trimming them from there.
any good woodworker should be able to extend one of these and have it be not only safe but look acceptable – with the help of modern adhesives.
  object(stdClass)#5084 (12) {
Check section 1013 of the building code suggests a 34 inch rail may be compliant.
jen-kg | 6 years and 5 months ago
  object(stdClass)#5085 (12) {
    string(6) "195100"
    string(6) "jen-kg"
    string(6) "jen-kg"
  int(195100)
@Urbandad the railing and newel would have been grandfathered in if we hadn’t had to rebuild the stairs.
JohnHancock | 6 years and 5 months ago
object(WP_User)#5084 (8) {
  object(stdClass)#5082 (12) {
    string(5) "22067"
    string(11) "JohnHancock"
  int(22067)
I have one just like that, original solid walnut 44″ tall
object(WP_User)#5085 (8) {
  object(stdClass)#5079 (12) {
so can adriatic wood products in east ny. it’d be nice to see if the OP can find a used one someplace.
yudashasom | 6 years and 5 months ago
  object(stdClass)#5086 (12) {
Heights Woodwork can make it.
You probably won’t find an original newel 42″, and I doubt it will look right. For a handrail in certain situations I think the code allows less. If you get close enough perhaps you can shim up the newel a few inches by extending it’s base. Check the code carefully. Good luck.
  object(stdClass)#5087 (12) {
    string(6) "195100"
    string(6) "jen-kg"
    string(6) "jen-kg"
  int(195100)
@johnhancock – found email and replied. Thank you
@cate – that’s what the original one looked like even though I think our house was built around 1900 (brick townhouse in south slope). I’m hoping I can find a woodworker who can make a replica. Not sure a salvaged one will work for height, but maybe. We ended up having to redo the stairs and the height of the original railing wouldn’t pass code and therefore the old newel wouldn’t work. Adventures in renovations!
  object(stdClass)#5080 (12) {
That’s a mid-19th century newel post if you’re interested. The square ones are later. You may be able to find others at a salvage yard.
object(WP_User)#5087 (8) {
    string(5) "22067"
  int(22067)
I sent you some pics, not sure if I got your email right
    string(6) "195100"
    string(6) "jen-kg"
    string(6) "jen-kg"
  int(195100)
thanks!
michelle m starr
gmail
    string(5) "22067"
  int(22067)
I have one that I bought at Olde Good Things not long ago and didn’t use. Send me your email and I’ll send you a pic
