induction range
I am thinking of using an induction range rather than gas in the house we are renovating, but I have never used one. Does anyone have experience, for or against?
28
string(6) "200749"
Per chipito, cast iron would work, for example
string(6) "200749"
My dad has one too, You need induction pots and pans. They sell dual ones that work on induction as well as gas burners.
Putnamdenizen | 4 years and 10 months ago
object(WP_User)#5036 (8) {
  object(stdClass)#5035 (12) {
    string(4) "1667"
    string(13) "Putnamdenizen"
    string(13) "putnamdenizen"
  int(1667)
My sister has one. The one thing I don’t like is that you aren’t always sure how well it is centered over the heat source. Also I had difficulty getting. a pan evenly heated up. It was very hot right over the the “burner” but not elsewhere in pan. I think I may not have been using it right. I think the pan needs to line up exactly to the size of the induction unit below, so that all parts of the pan are “induced.” There is obviously a learning curve. That said, I plan to replace my dual fuel range with an induction range when it finally dies….
chipito | 4 years and 10 months ago
object(WP_User)#5005 (8) {
  object(stdClass)#5006 (12) {
    string(6) "179751"
    string(7) "chipito"
    string(63) "$wp$2y$10$JqZ3R2KoP46vGEkh2wfcxuAZYgn7RLhjzYg9onMHhlbD22hVsUYea"
    string(7) "chipito"
    string(19) "jcmcnamee@gmail.com"
    string(29) "http:///forums/users/chipito/"
    string(7) "chipito"
  int(179751)
I think most of your current pots and pans would work, @cate, anything that a magnet will stick to on the bottom.
cate | 4 years and 10 months ago
object(WP_User)#5037 (8) {
  object(stdClass)#5019 (12) {
It sounds promising but I’d like to try it out first. About six months ago, the corner appliance repair shop near us had a used Viking induction range for sale for $1500! It was tempting but I wanted more info before buying, adding dedicated electric service, buying new pots and pans, etc.
object(WP_User)#5008 (8) {
  object(stdClass)#5034 (12) {
    string(6) "179751"
    string(7) "chipito"
    string(7) "chipito"
    string(7) "chipito"
  int(179751)
We’re planning on switching in the future for all the same reasons @brokelin mentioned.
brokelin | 4 years and 10 months ago
  object(stdClass)#5244 (12) {
    string(5) "90954"
    string(8) "brokelin"
  int(90954)
I haven’t had one, but I am completely sold on the concept and can’t wait to redo my kitchen with induction cooktop and smaller separate oven.
The advantages seem to be major: Heats up fast (so cooking time is faster); has the advantage like gas (over electric) in that you can raise or reduce heat immediately when cooking (this for me has been the major drawback when I’ve had to cook on regular electric, and why chefs prefer gas); and also the cooktop cools down fast – it supposedly doesn’t even get hot given how induction works.
And, for those of us with asthma or just concerned about health, cooking with gas creates a fair amount of indoor air pollution that is unhealthy for anyone – I am sure I will breathe easier in cleaner air. (This has probably been made worse by cooking almost all my adult life on gas stoves with no fan that vented to the outdoors in converted brownstones or older apartment buildings – sometimes I had a window in the kitchen, but I can’t say I regularly opened it when cooking.) I now have a fan that vents outside, but I can’t wait to install an induction cooktop.
I used to love gas (over electric), but then I changed my mind when I found out about the advantages of induction and the unhealthiness of gas.
object(WP_User)#5034 (8) {
  object(stdClass)#5037 (12) {
is that the thing with the glass top and something underneath? my father has one. i can say this, it is easy as anything to clean (flat smooth surface, not iron parts to lift out). might be worth it from that standpoint.
not something i would buy. i will have gas until someone puts me someplace where someone is making the decisions for me.
