glass roof for screened deck?
Has anyone looked into the possibility of screening a deck against insects by installing a glass roof and screens? Apparently the DOB says a deck cannot have a roof, so what would be the administrative hurdles?
I may have inadvertently added confusion. If the roof is temporary then the deck it is not a considered a room once that is removed. I was referring to the roof covering as “temporary” not the entire structure. You should talk to an architect and see if the room can be filed and added.
agdipierro
object(WP_User)#5020 (8) {
string(6) "193981"
string(10) "agdipierro"
int(193981)
For a better understanding of Temporary Structures, not to be confused with Temporary Construction, refer to NYC Building Code Section 3103.
I second Steve, if it can be removed easily it is not considered a room as it’s temporary.
object(WP_User)#4989 (8) {
object(stdClass)#4988 (12) {
can you make it temporary and detachable? they complain, you take it down until next year? take it down in the winter?
if it has a roof it’s considered another room, which may or may not be permitted based on the FAR in use on the lot already. plus it would be treated as a room for code compliance so would need things like outlets, etc I think. what if you had a retractable awning that screen fabric could be attached to?
