Garden floor bathroom smell
We have garden floor with a full bathroom. Lately it seems like there is a constant smell in there. The cellar is right below that bathroom, and when I go down there, I don’t smell anything, so it seems like it must be an odor emanating from the waste line in either the shower and / or the sink. But any other things I should consider as the root cause or why this could be happening? It is a seldomly used bathroom, if that could have anything to do with it.
xuytbjicwnofjdde
in General Discussion 2 years and 3 months ago
justinromeu26 | 2 years and 3 months ago
object(WP_User)#5166 (8) {
  object(stdClass)#5178 (12) {
dead animals and sewage odors are two very entirely different sorts of odors. a dead (and rotting) animal will make you want to vomit (perhaps it is a safety reflex so we don’t eat rotten meat). Sewer gas is not pleasant but it is also not the sort of thing that will make one vomit.
xuytbjicwnofjdde | 2 years and 3 months ago
object(WP_User)#5167 (8) {
  object(stdClass)#5168 (12) {
    string(6) "209569"
    string(16) "xuytbjicwnofjdde"
  int(209569)
Wow, that is really gross – i hope it’s not a dead rodent!
cate | 2 years and 3 months ago
object(WP_User)#5171 (8) {
  object(stdClass)#5165 (12) {
We had something that died in a wall cavity once and at first I thought raw sewage was spilling into the area.
lizeist | 2 years and 3 months ago
  object(stdClass)#5164 (12) {
    string(6) "191289"
    string(7) "lizeist"
    string(34) "$P$Br4OZ0r3cflEU8VhH.i/32LHC9V0SM1"
    string(7) "lizeist"
    string(21) "elizabeth@lonigro.com"
    string(19) "2024-02-22 17:00:41"
    string(35) "Elizabeth LoNigro Elizabeth LoNigro"
  int(191289)
Rat or mouse nest inside the walls?
object(WP_User)#5224 (8) {
  object(stdClass)#5636 (12) {
do you use that bathroom regularly? if you have not used it in months, run the water in the sink and shower to ensure the traps are full of water. if they run out, sewer gases will enter the living space.
  object(stdClass)#5637 (12) {
Possibilities:
A trap has dried out or is leaking. Run the water, refill the trap, see if it’s wet, etc.
Blockage in one of the lines.
A fixture is not vented. Or the vent is blocked. This can happen in snowy weather and other weather conditions.
It’s not the sewer at all but mold that smells like mushrooms and often smells just like the sewer. Just a few tiny drops of water getting down into wood such as floor boards or plywood with just a very small amount of mold can cause this.
