front garden
we are having a rat problem on our block; i hired exterminators to help; however, i am finding burrows again in the front yard; i need a recommendation for someone to install something in the yard to prevent the rats from burrowing; any recommendations would be appreciated
terryhoppy
23
Guest User | 3 years ago
string(6) "202751"
If you care about the hawks we have in the city then be careful what poison you use. Many of them kill birds when the birds opportunistically snatch up a rat scurring around not under cover after it ingests poison. We would have more natural rat predators to keep pest numbers down if we implemented more exclusion services and less poison. I had a landscaper successfully use dry ice before closing up garden burrows with metal mesh and concrete reinforcements at perimeter
sprothenberg17 | 3 years ago
object(WP_User)#4967 (8) {
  object(stdClass)#4966 (12) {
    string(6) "190541"
    string(14) "sprothenberg17"
    string(34) "$P$BVOLgyg9CNOIijjfH2dlBkSTrqCJ6C/"
    string(24) "sprothenberg17@gmail.com"
    string(19) "2023-02-28 01:42:42"
    string(33) "perry Rothenberg perry Rothenberg"
  int(190541)
There are a few products on the market that may be able to help you. You could look into rat barriers, which are barriers that can be installed around your yard to make it difficult for rats to burrow. You could also look into rat repellents, which are sprays that can be used to make the area less attractive to rats. Finally, you could consider using bait stations, which are containers that can be placed around the yard and filled with bait to attract and trap rats. I hope this helps!
object(WP_User)#5487 (8) {
  object(stdClass)#5488 (12) {
    string(6) "190541"
  int(190541)
object(WP_User)#4966 (8) {
  object(stdClass)#5238 (12) {
What can i do to keep them from going under my shed?
terryhoppy | 3 years and 1 month ago
object(WP_User)#5488 (8) {
  object(stdClass)#4967 (12) {
    string(6) "144730"
    string(10) "terryhoppy"
  int(144730)
what about putting crushed bluestone down
Guest User | 3 years and 1 month ago
string(6) "198332"
First step is to locate all of the burrows, then fill with Dry Ice, fill the holes with dirt – the CO2 will put the rats to sleep… forever. I do not believe this is legal in NY, however it 100% works and you can source dry ice from https://brooklyndryice.com/
Then as mentioned above, lay wire mesh and top with landscape fabric and decorative stones if you wish to stop any further burrowing.
sterlingbk | 3 years and 1 month ago
object(WP_User)#5481 (8) {
  object(stdClass)#5480 (12) {
    string(6) "180542"
    string(10) "sterlingbk"
    string(34) "$P$BX9IOLUg1q9ULO8NG9SKTQjY0MCfoT."
    string(19) "gabegodin@gmail.com"
    string(19) "2017-08-10 14:09:43"
  int(180542)
we put chicken wire down below the surface and surrounded the plants and trees, then covered up with river rocks. so far so good…
object(WP_User)#5479 (8) {
  object(stdClass)#5478 (12) {
if you are going to use poison, sometimes you have to use a lot of fast killing product at once to get them all so they all die. if you do not kill them all, the survivors will come to realize what they poison is and they will not go near it.
the other school of thought on this is to kill them slowly using something a little less toxic. then they do not realize what is doing it and they all slowly croak.
lai819199957 | 3 years and 1 month ago
object(WP_User)#5482 (8) {
  object(stdClass)#5473 (12) {
    string(6) "190495"
    string(12) "lai819199957"
    string(34) "$P$Bqzex7i4wRg5MWwmorwTbzBJeei0zx0"
    string(22) "lai819199957@gmail.com"
    string(19) "2023-02-10 06:05:04"
  int(190495)
I had some success. Used traps and poison to aggressively kill over 2 weeks. Then putting mothballs and more poison in the holes and refilling. Then scrubbing all possible routes they were taking to the garden with diluted vinegar to remove the scent. They follow established routes by scent apparently. And yeah, using trash bins so there is no food source near the front yard.
cate | 3 years and 1 month ago
object(WP_User)#5478 (8) {
  object(stdClass)#5475 (12) {
This article from Brooklyn Botanic Garden has a ton of useful information about how to deter rats from nesting in your garden. https://www.bbg.org/gardening/article/managing_rats_in_city_gardens
colonialrevival | 3 years and 1 month ago
object(WP_User)#5491 (8) {
  object(stdClass)#5492 (12) {
    string(6) "195334"
    string(15) "colonialrevival"
  int(195334)
How do you and your neighbors dispose of trash? A rolling tote can make a big difference.
jefferyngleaves | 3 years and 1 month ago
  object(stdClass)#5493 (12) {
    string(6) "190442"
    string(15) "jefferyngleaves"
    string(34) "$P$BjHqFGEXNWS4eWuk8V8o3j4dWNMdpI/"
    string(25) "jefferyngleaves@gmail.com"
    string(19) "2023-01-27 12:56:43"
    string(31) "Jeffery Gleaves Jeffery Gleaves"
  int(190442)
Have you tried those things you stick in the ground that emit some kind of frequency that keeps them away? Don’t know what they’re called but a couple I know had success with them.
string(6) "202751"
kiltsjeremy@gmail.com
object(WP_User)#4995 (8) {
  object(stdClass)#4996 (12) {
    string(6) "144730"
  int(144730)
jeremy can i have your email. thx
anotherposter | 3 years and 1 month ago
object(WP_User)#4962 (8) {
  object(stdClass)#4997 (12) {
    string(5) "53767"
    string(13) "anotherposter"
  int(53767)
We had a pest company say that once they start nesting somewhere it’s hard to stop them, and I think it was because of the scents. Maybe replacing the soil and using some enzymatic cleaners (like Nature’s Miracle for cats/dogs) could help?
string(6) "202751"
My buddy has a solution on predatory birds. Not a bad idea. But if becomes czar then he might have to explain missing toy poodles?
patrickburnsjr | 3 years and 1 month ago
object(WP_User)#5490 (8) {
    string(6) "193383"
    string(14) "patrickburnsjr"
  int(193383)
Nor good.
…NYC is still looking for a ‘Rat Czar”…almost 1000 people have applied.
irfan | 3 years and 1 month ago
  object(stdClass)#5489 (12) {
    string(6) "189280"
    string(5) "irfan"
    string(34) "$P$BJs4ee.fUAi5QmHT9T0O4EeUJNgiI9."
    string(5) "irfan"
    string(21) "irfan@fieldpromax.com"
    string(19) "2021-12-17 09:43:22"
    string(25) "Field Promax Field Promax"
  int(189280)
Wow… if only NYC parks would take that advice!
object(WP_User)#5474 (8) {
  object(stdClass)#5241 (12) {
    string(6) "189280"
    string(5) "irfan"
    string(5) "irfan"
  int(189280)
