Fireplace disturbing neighbors
A new development, my next door neighbors have started to smell (not sure if they can see) smoke when we have a fire in our fireplace. Additional details below:
– My unit is the floor of a prewar townhouse. All townhouses on the block are connected (but not identical).
– The fireplace is on the “shared” wall with the neighbors (divided by two walls and a thick layer of brick).
– Our seller’s had the chimney re-lined, and we had the unit inspected (both about 1 year ago). The fire dept came, looked at our fire, and said it was working properly.
– The chimney functions properly, and there is no smoke in our unit.
– We’ve had a handful of fires, and this has never happened.
– The neighbors don’t have a fireplace or any vents (no central AC).
Any idea what could be happening here? I feel like we’ve had all of the inspections we can, but I’m worried this indicates some kind of hazard.
murray.faithk
11
hkapstein | 2 years and 3 months ago
object(WP_User)#5156 (8) {
object(stdClass)#5168 (12) {
Thanks for the follow up. Indeed I am very familiar with this configuration, but I would not normally refer to that as a flue, although being a passageway in the chimney, I see why some might call it that. But you obviously can’t vent your flue gas into something that terminates in the building. You’d have to install a flue liner up to the roof, and vent it out the chimney. And if that were done correctly, it should not vent smoke into the neighboring building.
The party wall may be thinner at the chimney, but 1.5 standard brick wythes should be well over 4 inches. However when you build a fire, you may not notice the smell of smoke as much in your unit as would the neighbors who are not making a fire. So it’s possible that there is an air passage between the buildings as you commented. However I have installed a fireplace in this type of system and we did not have a problem. But we did use a prefab fireplace.
stoopsitter | 2 years and 3 months ago
object(WP_User)#5157 (8) {
object(stdClass)#5158 (12) {
string(3) "899"
string(11) "stoopsitter"
string(2) "JB"
int(899)
In answer to Urbandad, the chimney functioned as a vent for the forced hot air system. A coal-fired furnace in the cellar produce hot air which rose by gravity through the flues and then, via the “summer” grills, into every large room in the house. Also, the party wall is only 1.5 bricks deep in our row of brownstones — as we and various neighbors have discovered during plumbing projects!
justinromeu26 | 2 years and 3 months ago
object(WP_User)#5161 (8) {
object(stdClass)#5155 (12) {
has the fireplace or smoke chamber been “parged”? if not, talk to the chimney people about this-
cate | 2 years and 3 months ago
object(stdClass)#5154 (12) {
Possibly a fireplace could be coal or gas (with fake logs) and later be converted to forced air or the fireplace itself was used to distribute forced air. Another possibility, and something you see a lot in circa 1850s-1860s Italianate houses, is rooms that had a mantel and a shallow chimney and firebox but were only ever meant to work with a heating stove (coal or wood). So there was no combustion in the firebox, only in the heating stove, whose vent pipe was attached to the chimney to vent out the flue. Much later houses (1880s-1910s) sometimes have shallow bump-outs in the living room that originally held console mirrors. These were never chimneys and never held mantels.
object(WP_User)#5153 (8) {
object(stdClass)#5152 (12) {
ha, i have been wondering that since the day i read this-
we had a fake fire place in this house when we moved into and i used wonder, “why bother?”. at least ours did not have a flue.
object(stdClass)#5151 (12) {
Why would a decorative only fireplace have a flue at all? Anyway, there’s no reason a properly installed fireplace shouldn’t work safely, whether it was initially a solid fuel burning fireplace or not. You might take a look at a bellfires fireplace. They make very small wood burning fireplace units that will often fit in a shallow coal burning firebox area. The prefabricated and ceramic wool insulated firebox in connection with your properly lined chimney should vent your flue gasses completely and avoid heating the structure and freaking out neighbors.
object(WP_User)#5152 (8) {
object(stdClass)#5156 (12) {
string(3) "899"
string(2) "JB"
int(899)
Smoke is like water: if there are even tiny cracks in the party wall, it will find a way. We had a situation where we had an expensive terracotta flue inserted into the chimney and an entirely new smoke chamber built by a licensed chimney mason. They left a tiny hole in the smoke chamber. Smoke then entered the old chimney and, from there, leaked through the party wall. We had that fixed, only to then discover that the party wall became very hot whenever we had a fire. In the end we abandoned having open fires. It wasn’t worth the hassle with our neighbor and, more importantly, the fire risk. It was a huge waste of money. With hindsight, our chimney mason should have told us the chimney wasn’t suitable for conversion but he preferred to take our money. I advise seeking the opinion of an independent structural engineer. We later learned none of our row of brownstones had had solid fuel burning hearths. The original heating system was forced hot air and the fireplaces were only ever decorative.
object(WP_User)#5151 (8) {
object(stdClass)#5153 (12) {
Big Apple Chimney also said the place to start would be with the people who did the original inspection. Be aware that if a Home Inspector did that inspection during a buyer’s home inspection, it was probably what is known as a level I inspection and it will not go into the detail of a Level II which looks at the insides and up/down the flue. It sounds to me like OP would want the level II with perhaps other tests.
object(stdClass)#5157 (12) {
I second the recommendation to call a chimney expert and see what they say.
OP, i did make a call to Big Apple Chimney about this and spoke to Jason. He recommended you give them a call.
I made this call because i perform visual inspections of fireplaces and chimneys as part of my home inspection business but what i am qualified and equipped to do stops short of what i think you will need. Places like Big Apple have more extensive training and the equipment needed to do other things. You may wish to call them and see what they recommend (they do pressure tests, etc that only specialists should do).
Steve
Brownstone Home Inspection LLC.
Did a fire place and chimney specilist perform the first inspection? If so, i would call them and ask them if this is normal in these old houses. Specilists with proper certifications and insurance run great risk if they miss something or give you bad information. By putting the question to them you will force them to explain this situation.
My suspicion is it is simply a void in some brick someplace but if the liner was relined and they properly parged the top of the fire box and smoke chamber, i cannot understand how this is happening.
Also, you should have an inspection report from the people who did the inspection. Have you looked at comments in that report to see if any might correlate to what you are seeing now?
